Datasheet OP220 (Analog Devices) - 5
DescriptionDual Micropower Operational Amplifier - Obsolete
Pages / Page12 / 5 — Typical Performance Characteristics–OP220. 150. VS = 15V. 100. GE –. A T. …
Typical Performance Characteristics–OP220. 150. VS = 15V. 100. GE –. A T. OL V. –50. INPUT BIAS CURRENT – nA. INPUT OFFSET. –100. –150. –25. 125
Typical Performance Characteristics–OP220 150 VS = 15V 100 GE – A T OL V –50 INPUT BIAS CURRENT – nA INPUT OFFSET –100 –150 –25 125
Typical Performance Characteristics–OP220 150 14 VS = 15V VS = 15V 12 100 V
10 GE – 50 A T 8 OL V 0 6 –50 4 INPUT BIAS CURRENT – nA INPUT OFFSET –100 2 –150 0 –50 –25 0 25 50 75 100 125 –100 –50 0 50 100 150 TEMPERATURE –
C TEMPERATURE –
C
TPC 1. Normalized Offset Voltage vs. Temperature TPC 4. Input Bias Current vs. Temperature
80 700 TA = 25
C VS = 15V 60 600 V
40 500 GE – A T OL 20 400 V 0 300 –20 200
INPUT OFFSET INPUT OFFSET CURRENT – pA –40 100 –60 0 0 4 8 12 16 20 –100 –50 0 50 100 150 POWER SUPPLY VOLTAGE – V TEMPERATURE –
C
TPC 2. Input Offset Voltage vs. Power Supply Voltage TPC 5. Input Offset Current vs. Temperature
110 200 VS = 15V 100 180 90 TA = 125
C 10Hz 80 A
160 70 140 60 100Hz TA = 25
C 50 OBSOLETE 120 Y CURRENT – 40 1kHz OPEN-LOOP GAIN – dB 30 SUPPL 100 TA = –55
C 20 80 10 0 60 –75 –50 –25 0 25 50 75 100 125 0 2.5 5.0 7.5 10.0 12.5 15.0 17.5 TEMPERATURE –
C SUPPLY VOLTAGE – V
TPC 3. Open-Loop Gain vs. Temperature TPC 6. Supply Current vs. Supply Voltage REV. A –5– Document Outline FEATURES GENERAL DESCRIPTION PIN CONFIGURATIONS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS DIE CHARACTERISTICS ORDERING GUIDE WAFER TEST LIMITS Typical Performance Characteristics INSTRUMENTATION AMPLIFIER APPLICATIONS OF THE OP220 Two Op Amp Configuration THREE OP AMP CONFIGURATION OUTLINE DIMENSIONS Revision History
