Datasheet AD7293 (Analog Devices) - 77
Description12-Bit Power Amplifier Current Controller with ADC, DACs, Temperature and Current Sensors
Pages / Page79 / 77 — Data Sheet. AD7293. VPP. REF. ADC. REFOUT. VREFIN. PAVDD. PRECISION. …
RevisionD
Data Sheet. AD7293. VPP. REF. ADC. REFOUT. VREFIN. PAVDD. PRECISION. PMOS. BI-VOUT0MON. 2.5V. CONTROL. PA_ON. BI-V. REFERENCE. OUT1MON. RS3+
Data Sheet AD7293 VPP REF ADC REFOUT VREFIN PAVDD PRECISION PMOS BI-VOUT0MON 2.5V CONTROL PA_ON BI-V REFERENCE OUT1MON RS3+
Data Sheet AD7293 VPP REF V ADC REFOUT VREFIN PAVDD PRECISION PMOS BI-VOUT0MON 2.5V CONTROL PA_ON BI-V REFERENCE OUT1MON RS3+ BI-VOUT2MON BI-VOUT3MON 1 R × SENSE RFOUT 2 RS3– DACVDD-BI BI-V 1.25V 2.5V BIPOLAR OUT3 RFIN FILTER GaN DACV DAC + DD-UNI RS2+ AVSS RSENSE RFOUT AV RS2– DD BI-VOUT2 BIPOLAR RFIN FILTER GaN V DAC + IN0 Tx POWER RS1+ MONITOR V AD7293 IN1 RSENSE RS1– RFOUT Rx POWER VIN2 MONITOR BI-VOUT1 RFIN BIPOLAR FILTER GaN VIN3 MUX DAC + RS0+ T CONTROL RSENSE D0+ BI RS0– RFOUT LOGIC 12- AR ADC S BI-V 1 OUT0 BIPOLAR RFIN FILTER GaN DAC + D0– UNI-V UNIPOLAR OUT0 GAIN D1+ URE R DAC CONTROL 1 RAT SO E UNI-VOUT1 UNIPOLAR GAIN P DAC M SEN CONTROL D1– E T UNI-VOUT2 UNIPOLAR GAIN DAC CONTROL ALERT AND LIMIT REGISTERS UNI-VOUT3 UNIPOLAR GAIN DAC CONTROL VDRIVE DAC VCLAMP0 RESET SPI DIGITALI/Os CLAMP DV LOGIC INTERFACE DD CONTROL VCLAMP1 T K N K T Y C S UT CS N S S T0 T1 A ND ND DI CL V U R R ESET TE S DO LA EEP0 EEP1 /B /LD DG AG LE R LE Y B ON /C /A /A /SL /SL /IS IO2 5 6 IO7 O O TOR IO1 GP IO3 IO4 GP
059
C IO0 PI PI FA GP GP GP G G GP
13016- Figure 59. Typical Power Amplifier Control Application
DEPLETION MODE AMPLIFIER BIASING AND
The AD7293 was designed for depletion mode power amplifier
PROTECTION
biasing. Bipolar DAC outputs enable negative voltage biasing of Depletion mode devices (for example, gallium nitride (GaN) or the gate on the depletion mode device. A closed-loop mode gallium arsenide (GaAs)) require temperature compensated combined with a low temperature drift reference ensures that gate biasing voltages similar to enhancement mode devices (for the loop is steady over temperature. example, laterally diffused metal oxide semiconductor (LDMOS)) The AD7293 works to ensure that instability or destruction of to maintain constant quiescent drain current with temperature. the depletion mode device is avoided. A PA_ON signal allows The most important consideration for a depletion mode device the user the option to control an external PMOS switch to turn is the biasing sequence. If the gate of a depletion mode device is on and off the drain current. This signal is set to the off state on at 0 V and the drain voltage is applied, the device may be power-up. Because depletion mode devices require a negative damaged by drawing excessive current. It is also likely that a bias to remain at an acceptable level, and bipolar DACs transmit device may become potentially unstable at lower drain source on the AVSS supply for proper operation, PA_ON can be triggered voltages. Therefore, decreasing the gate voltage to less than the when AVSS exceeds an acceptable level. pinch off voltage while the drain voltage is being powered on In the event of an AVDD voltage supply failure, the bipolar DACs and off is necessary. clamp to the AVSS supply (−5 V), which ensures that the PA Rev. D | Page 77 of 79 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION SIMPLIFIED FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAMS SPECIFICATIONS ADC DAC TEMPERATURE SENSOR CURRENT SENSOR CLOSED-LOOP SPECIFICATIONS GENERAL TIMING CHARACTERISTICS SPI Serial Interface Asynchronous Inputs Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG-TO-DIGITAL CONVERTER (ADC) OVERVIEW ADC TRANSFER FUNCTIONS ANALOG INPUTS Single-Ended Mode Differential Mode Pseudo Differential Mode CURRENT SENSOR Choosing the External Sense Resistor (RSENSE) TEMPERATURE SENSOR INTERNAL CHANNEL MONITORING DAC OPERATION Bipolar DACs Unipolar DACs DAC Enabling and Clamping Software Clamping: Internal ALERT0 Routing PMOS Drain Switch Control REFERENCE VDRIVE FEATURE OPEN-LOOP MODE CLOSED-LOOP MODE Adjustable Closed-Loop Setpoint Ramp Time Fast Ramp Feature Closed-Loop Sequencing Closed-Loop Integrator Programmable Voltage Limit Closed-Loop Range Upper Voltage Limit DIGITAL INPUT/OUTPUT REGISTERS LOAD DAC (LDAC PIN) Instantaneous DAC Updating (Asynchronous) Deferred DAC Updating (Synchronous) ALERTS AND LIMITS ALERTx Pins Software Alerts Page GPIO0 to GPIO3 Routing to ALERT1 AVDD AND AVSS ALARM MAXIMUM AND MINIMUM PAGES HYSTERESIS REGISTER SETTINGS REGISTERS COMMON TO ALL PAGES No Op Register (Register 0x00) Page Select Pointer Register (Register 0x01) Conversion Command (Register 0x02) Result Register (Register 0x03) DAC Enable Register (Register 0x04) GPIO Register (Register 0x05) Device ID Register (Register 0x0C) Software Reset Register (Register 0x0F) RESULT 0/DAC INPUT (PAGE 0x00) Voltage Input (VINx) Result Registers (Register 0x10 to Register 0x13) Temperature Sensor (TSENSEINT and TSENSEDx) Result Registers (Register 0x20 to Register 0x22) Current Sensor (ISENSEx) Result Registers (Register 0x28 to Register 0x2B) DAC Input (UNI-VOUTx and BI-VOUTx) Registers (Register 0x30 to Register 0x37) RESULT 1 (PAGE 0x01) Voltage Supply Monitor Result Registers (Register 0x10 to Register 0x13) Bipolar DAC Internal Monitor Result (BI-VOUT0MON to BI-VOUT3MON) Registers (Register 0x14 to Register 0x17) RSx+MON Result Registers (Register 0x28 to Register 0x2B) CONFIGURATION (PAGE 0x02) Digital Output Enable Register (Register 0x11) Digital Input/Output Function Register (Register 0x12) Digital Functional Polarity Register (Register 0x13) General Register (Register 0x14) VINx Range x Registers (Register 0x15 and Register 0x16) VINx Differential/Single-Ended Enable Register (Register 0x17) VINx Filter Register (Register 0x18) VINx Background Enable Register (Register 0x19) Conversion Delay Register (Register 0x1A) Temperature Sensor (TSENSEx) Background Enable Register (Register 0x1B) Current Sensor (ISENSEx) Background Enable Register (Register 0x1C) Current Sensor (ISENSEx) Gain Register (Register 0x1D) DAC Snooze/SLEEP0 Pin Register (Register 0x1F) DAC Snooze/SLEEP1 Pin Register (Register 0x20) RSx+MON, Supply Monitor, BI-VOUTx Background Enable Register (Register 0x23) Integrator Limit and Closed-Loop Control Register (Register 0x28) PA_ON Control Register (Register 0x29) Ramp Time 0 to Ramp Time 3 Registers (Register 0x2A to Register 0x2D) Closed-Loop Fast Ramp and Integrator Time Constant Register (Register 0x2E) Integrator Limit Active Status (INTLIMITx) and AVSS/AVDD Alarm Mask Register (Register 0x2F) SEQUENCE (PAGE 0x03) Voltage Input (VINx) Sequence Register (Register 0x10) Current Sensor (ISENSEx) and Temperature Sensor (TSENSEx) Sequence Register (Register 0x11) RSx+MON, Supply Monitor, and BI-VOUTx Monitor Sequence Register (Register 0x12) HIGH LIMIT 0 (PAGE 0x04) VINx High Limit Registers (Register 0x10 to Register 0x13) Temperature Sensor (TSENSEx) High Limit Registers (Register 0x20 to Register 0x22) Current Sensor (ISENSEx) High Limit Registers (Register 0x28 to Register 0x2B) HIGH LIMIT 1 (PAGE 0x05) AVDD, DAC Supply (DACVDD-UNI/DACVDD-BI) and AVSS High Limit Registers (Register 0x10 to Register 0x13) BI-VOUT0MON to BI-VOUT3MON High Limit Registers (Register 0x14 to Register 0x17) RSx+MON High Limit Registers (Register 0x28 to Register 0x2B) LOW LIMIT 0 (PAGE 0x06) VINx Low Limit Registers (Register 0x10 to Register 0x13) Temperature Sensor (TSENSEx) Low Limit Registers (Register 0x20 to Register 0x22) Current Sensor (ISENSEx) Low Limit Registers (Register 0x28 to Register 0x2B) LOW LIMIT 1 (PAGE 0x07) AVDD, DAC Supply (DACVDD-UNI/DACVDD-BI), and AVSS Low Limit Registers (Register 0x10 to Register 0x13) BI-VOUT0MON to BI-VOUT3 MON Low Limit Registers (Register 0x14 to Register 0x17) RSx+MON Low Limit Registers (Register 0x28 to Register 0x2B) HYSTERESIS 0 (PAGE 0x08) VINx Hysteresis Registers (Register 0x10 to Register 0x13) Temperature Sensor (TSENSEx) Hysteresis Registers (Register 0x20 to Register 0x22) Current Sensor (ISENSEx) Hysteresis Registers (Register 0x28 to Register 0x2B) HYSTERESIS 1 (PAGE 0x09) AVDD, DAC Supply (DACVDD-UNI/DACVDD-BI), and AVSS Hysteresis Registers (Register 0x10 to Register 0x13) BI-VOUT0MON to BI-VOUT3MON Hysteresis Registers (Register 0x14 to Register 0x17) RSx+MON Hysteresis Registers (Register 0x28 to Register 0x2B) MINIMUM 0 (PAGE 0x0A) VINx Minimum Registers (Register 0x10 to Register 0x13) Temperature Sensor (TSENSEx) Minimum Registers (Register 0x20 to Register 0x22) Current Sensor (ISENSEx) Minimum Registers (Register 0x28 to Register 0x2B) MINIMUM 1 (PAGE 0x0B) AVDD, DAC Supply (DACVDD-UNI/DACVDD-BI), and AVSS Minimum Registers (Register 0x10 to Register 0x13) BI-VOUT0MON to BI-VOUT3MON Minimum Registers (Register 0x14 to Register 0x17) RSx+MON Minimum Registers (Register 0x28 to Register 0x2B) MAXIMUM 0 (PAGE 0x0C) VINx Maximum Registers (Register 0x10 to Register 0x13) Temperature Sensor (TSENSEx) Maximum Registers (Register 0x20 to Register 0x22) Current Sensor (ISENSEx) Maximum Registers (Register 0x28 to Register 0x2B) MAXIMUM 1 (PAGE 0x0D) AVDD, DAC Supply (DACVDD-UNI/DACVDD-BI), and AVSS Maximum Registers (Register 0x10 to Register 0x13) BI-VOUT0MON to BI-VOUT3MON Maximum Registers (Register 0x14 to Register 0x17) RSx+MON Maximum Registers (Register 0x28 to Register 0x2B) OFFSET 0 (PAGE 0x0E) VINx Offset Registers (Register 0x10 to Register 0x13) Temperature Sensor (TSENSEx) Offset Registers (Register 0x20 to Register 0x22) Current Sensor (ISENSEx) Offset Registers (Register 0x28 to Register 0x2B) Unipolar DAC (UNI-VOUTx) Offset Registers (Register 0x30 to Register 0x33) Bipolar DAC (BI-VOUTx) Offset Registers (Register 0x34 to Register 0x37) OFFSET 1 (PAGE 0x0F) AVDD, DAC Supply (DACVDD-UNI/DACVDD-BI), and AVSS Offset Registers (Register 0x10 to Register 0x13) BI-VOUT0MON to BI-VOUT3 MON Offset Registers (Register 0x14 to Register 0x17) RSx+MON Offset Registers (Register 0x28 to Register 0x2B) ALERT (PAGE 0x10) Alert Summary (ALERTSUM) Register (Register 0x10) VINx Alert Register (Register 0x12) Temperature Sensor (TSENSEx) Alert Register (Register 0x14) Current Sensor (ISENSEx) Alert Register (Register 0x15) Supply and BI-VOUTxMON Alert Register (Register 0x18) RSx+MON Alert Register (Register 0x19) INTLIMITx and AVSS/AVDD Alert Register (Register 0x1A) ALERT0 PIN ROUTING (PAGE 0x11) VINx ALERT0 Register (Register 0x12) Temperature Sensor (TSENSEx) ALERT0 Register (Register 0x14) Current Sensor (ISENSEx) ALERT0 Register (Register 0x15) Supply and BI-VOUTxMON ALERT0 Register (Register 0x18) RSx+MON ALERT0 Register (Register 0x19) INTLIMITx and AVss/AVDD ALERT0 Register (Register 0x1A) ALERT1 PIN ROUTING (PAGE 0x12) VINx ALERT1 Register (Register 0x12) Temperature Sensor (TSENSEx) ALERT1 Register (Register 0x14) Current Sensor (ISENSEx) ALERT1 Register (Register 0x15) Supply and BI-VOUTxMON ALERT1 Register (Register 0x18) RSx+MON ALERT1 Register (Register 0x19) INTLIMITx and AVSS/AVDD ALERT1 Register (Register 0x1A) SERIAL PORT INTERFACE INTERFACE PROTOCOL MODES OF OPERTION Background Mode (BG) Command Mode Current Sensor and Temperature Sensor Conversions Conversion Timing Current Sense and Temperature Sense Channel Integration Time Conversion and Integration Timing Example 1 Conversion and Integration Timing Example 2 Digital Filtering APPLICATIONS INFORMATION BASE STATION POWER AMPLIFIER CONTROL DEPLETION MODE AMPLIFIER BIASING AND PROTECTION LOOP COMPONENT SELECTION OUTLINE DIMENSIONS ORDERING GUIDE
