Datasheet ADuM6020, ADuM6028 (Analog Devices) - 9
DescriptionLow Emission, 5 kV Isolated DC-to-DC Converters
Pages / Page20 / 9 — Data Sheet. ADuM6020/. ADuM6028. 3.0. RECOMMENDED OPERATING CONDITIONS. …
File Format / SizePDF / 474 Kb
Data Sheet. ADuM6020/. ADuM6028. 3.0. RECOMMENDED OPERATING CONDITIONS. 2.5. Table 14. Parameter. Symbol Min Typ Max Unit. (W R E. 2.0. W O
Data Sheet ADuM6020/ ADuM6028 3.0 RECOMMENDED OPERATING CONDITIONS 2.5 Table 14 Parameter Symbol Min Typ Max Unit (W R E 2.0 W O
Data Sheet ADuM6020/ ADuM6028 3.0 RECOMMENDED OPERATING CONDITIONS 2.5 Table 14. ) Parameter Symbol Min Typ Max Unit (W R E 2.0
Operating Temperature1 TA −40 +125 °C
W O
Supply Voltages2 V
P
DDP
G 1.5 IN
ADuM6020-5BRWZ, 4.5 5.5 V
IT
ADuM6028-5BRIZ,
IM L 1.0
VDDP at VISO = 3.135
FE A
V to 3.465 V
S
ADuM6020-3BRWZ, 3.0 3.6 V
0.5
ADuM6028-3BRIZ, VDDP at VISO = 3.135 V
0
to 3.465 V
0 50 100 150 200
002 30- 165 ADuM6020-5BRWZ, 4.5 5.5 V Figure 3. ADuM6020 Thermal Derating Curve, Dependence of Safety Limiting ADuM6028-5BRIZ, Values with Ambient Temperature, per DIN V VDE V 0884-10 VDDP at VISO = 4.75 V to 5.25 V
1.8 1.6
1 Operation at >85°C requires reduction of the maximum load current. 2
Each voltage is relative to its respective ground.
1.4 (W R E 1.2 OW P 1.0 G IN IT 0.8 IM L 0.6 TY FE A 0.4 S 0.2 0 0 50 100 150 200
104 30-
AMBIENT TEMPERATURE (°C)
165 Figure 4. ADuM6028 Thermal Derating Curve, Dependence of Safety Limiting Values with Ambient Temperature per DIN V VDE V 0884-10 Rev. B | Page 9 of 20 Document Outline Features Applications Functional Block Diagrams General Description Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Regulatory Approvals Insulation and Safety Related Specifications Package Characteristics DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Truth Table Typical Performance Characteristics Theory of Operation Applications Information PCB Layout Thermal Analysis EMI Considerations Insulation Lifetime Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example Outline Dimensions Ordering Guide
