LTM4638 PACKAGE DESCRIPTION 6 Y SEE NOTES AR PIN 1 ACKAGE TED. Y V A B C D E F G 1 ATION AIL A BGA 49 1218 REV A DET 2 TIONAL, e 3 TOM VIEW 4 G Y BE EITHER A MOLD OR TING PLANE Y Y LOADING ORIENT 5 TED WITHIN THE ZONE INDICA 6 b PACKAGE BOT TION PER JEP95 TURE 7 TUM -Z- IS SEA PACKAGE IN TRA YOUT CAREFULL Y DA PACKAGE ROW AND COLUMN LABELING MA AMONG µModule PRODUCTS. REVIEW EACH P LA AILS OF PIN 1 IDENTIFIER ARE OP 3 b e ! DET BUT MUST BE LOCA THE PIN 1 IDENTIFIER MA MARKED FEA SEE NOTES F LL DIMENSIONS ARE IN MILLIMETERS PIN 1 NOTES: 1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M-1994 2. A 3 BALL DESIGNA 4 Y PIN 1 BEVEL 5. PRIMAR 6 TRA Z COMPONENT A2 A AIL B DET PACKAGE SIDE VIEW 5.02mm) TE THK × NOTES BALL HT BALL DIMENSION PAD DIMENSION SUBSTRA MOLD CAP HT INDUCTOR HT Z 6.25mm TE Y × X H1 MAX 5.36 0.50 1.69 0.55 0.43 0.15 0.10 0.20 0.20 0.08 A1 Z Z SUBSTRA BGA Package M M TC DWG# 05-08-1574 Rev A) ddd eee b1 AIL B AIL A DIMENSIONSNOM 5.02 0.40 1.52 0.50 0.40 6.25 6.25 0.80 4.80 4.80 H2 0.32 REF 1.20 REF 3.10 REF ccc Z DET MOLD CAP DET AL NUMBER OF BALLS: 49 // bbb Z TOT (Reference L MIN 4.68 0.30 1.41 0.45 0.37 49-Lead (6.25mm Øb (49 PLACES) H3 A A1 A2 b b1 D E e F G H1 H2 H3 aaa bbb ccc ddd eee SYMBOL aaa Z 2× D X Y 2.400 1.600 0.800 0.000 0.800 1.600 2.400 2.400 1.600 YOUT 0.800 0.000 E 5.48 ±0.20 0.800 TOP VIEW PACKAGE TOP VIEW 1.600 SUGGESTED PCB LA 2.400 aaa Z 2× 4 PIN 1 5.28 ±0.20 CORNER 0.40 REF Ø 49x Rev. B 28 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications For more information www.a subject to change without notice. No license is granted by implication or othernalog.com wise under any patent or patent rights of Analog Devices. Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Decoupling Requirements Operation Applications Information Package Description Revision History Package Photo Related Parts
