Datasheet MAX32670 (Maxim) - 8
ManufacturerMaxim
DescriptionHigh Reliability, Ultra-Low Power Microcontroller Powered by Arm Cortex M4 Processor with FPU for Industrial and IoT
Pages / Page44 / 8 — Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. …
File Format / SizePDF / 530 Kb
Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Electrical Characteristics (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX32670 High Reliability, Ultra-Low Power Microcontroller Powered by Arm Cortex M4 Processor with FPU for Industrial and IoT
(Limits are 100% tested at TA = +25ºC and TA = +105ºC. Limits over the operating temperature range and relevant supply voltage range are guaranteed by design and characterization. Specifications marked GBD are guaranteed by design and not production tested. Specifications to the minimum operating temperature are guaranteed by design and are not production tested.)
Monitors VDD 1.4 Power-On Reset V V Voltage POR Monitors VCORE during dual supply 0.65 operation 19-100782 www.maximintegrated.com Maxim Integrated | 8 Document Outline General Description Applications Benefits and Features Simplified Block Diagram Absolute Maximum Ratings Package Information 40 TQFN-EP Electrical Characteristics Electrical Characteristics (continued) Electrical Characteristics—SPI Electrical Characteristics—SPI (continued) Electrical Characteristics—I2C Electrical Characteristics—I2C (continued) Electrical Characteristics—I2S Slave Pin Configuration 40 TQFN Pin Description 40 TQFN Detailed Description MAX32670 Arm Cortex-M4 Processor with FPU Engine Memory Internal Flash Memory Internal SRAM Clocking Scheme General-Purpose I/O and Special Function Pins Standard DMA Controller Power Management Power Management Unit Active Mode Sleep Mode DeepSleep Mode Backup Mode Storage Mode Real-Time Clock Windowed Watchdog Timer (WWDT) 32-Bit Timer/Counter/PWM (TMR, LPTMR) Serial Peripherals I2C Interface (I2C) Serial Peripheral Interface (SPI) I2S Interface (I2S) UART (UART, LPUART) Security AES True Random Number Generator (TRNG) CRC Module Secure Boot Debug and Development Interface (SWD) Applications Information Bypass Capacitors Ordering Information Revision History
