Datasheet PEC11H (Bourns) - 2
Manufacturer | Bourns |
Description | 11 mm Encoder w/High Detent Force |
Pages / Page | 4 / 2 — Applications. PEC11H Series - 11 mm Encoder w/High Detent Force. Product … |
File Format / Size | PDF / 515 Kb |
Applications. PEC11H Series - 11 mm Encoder w/High Detent Force. Product Dimensions. PEC11H-4xxxF-Nxxxx. Dim. Tol. 18 TEETH. KNURLED
Applications
Level control, tuning and timer settings in: n Audio-visual equipment n Consumer electric appliances n Environmental controls n Musical instrumentation n Communications equipment
PEC11H Series - 11 mm Encoder w/High Detent Force Product Dimensions PEC11H-4xxxF-Nxxxx
0.5 11.8 0.75 C (.020) (.465) 6.0 M7XP (.030) (.236) 4.5 +0/-0.05 2 PLCS. 2.0 (.177 +0/-.002) 2.2 +0.2/-0 12.8 (.079) (.087 +.008/-0) (.504) 7.5 7.5 (.295) 6.0 1.4 +0.2/-0 (.295) F (.236) (.055 +.008/-0) DIA. A CHANNEL 6.0 3.0 A C B 1.0 +0.1/-0 A C B LB C COMMON (.236) (.118) (.039 +.004/-0) 5.0 B CHANNEL 6.5 DIA. 3 PLCS. (.197) L (.267) MOUNTING SURFACE LB P 1.0 C (.039) A
L LB F P A C Dim. Tol. 18 TEETH
15 5.0 5.0 7.0 6.0 6.0 <10.0 ±0.3
KNURLED
(.591) (.197) (.197) (.276) (.236) (.236) (<.394) (±.012) 6.0 20 7.0 10.0 7.0 6.0 7.0 10.0 ~ 100 ±0.5 0.8 DIA. L (.236) (.787) (.276) (.394) (.276) (.236) (.276) (.394 ~ 3.937) (±.020) (.032) 25 7.0 12.0 12.0 10.0 11.0 (.984) (.276) (.472) (.472) (.394) (.433) 13.6 (.535) 5.0 (.197)
PEC11H-4xxxF-Sxxxx
11.8 12.8 (.465) (.504) 0.5 5.0 5.0 0.75 C M7XP (.020) (.197) 6.0 (.197) (.030) S W (.236) S W 4.5 +0/-0.05 2 PLCS. 7.0 2.0 2.2 +0.2/-0 (.177 +0/-.002) 7.0 (.276) (.079) (.087 +.008/-0) (.276) 7.5 7.5 6.0 1.4 +0.2/-0 (.295) (.295) DIA. (.236) (.055 +.008/-0) F A CHANNEL 6.0 0.5 ± 0.3 1.0 +0.1/-0 A C B 3.0 LB C COMMON A C B (.236) (.020 ± .012) (.039 +.004/-0) 5.0 (.118) 6.5 SWITCH B CHANNEL DIA. 5 PLCS. (.197) L TRAVEL (.267) MOUNTING SURFACE 0.8
L LB F Dim. Tol.
(.032) 15 5.0 5.0 <10.0 ±0.3 (.591) (.197) (.197) (<.394) (±.012) 13.6 20 7.0 10.0 10.0 ~ 100 ±0.5 (.535) (.787) (.276) (.394) (.394 ~ 3.937) (±.020) 5.0 25 7.0 12.0 (.197) (.984) (.276) (.472)
PEC11H-2xxxK-Sxxxx
L 1.0 (.039) Specifications are subject 8.0 to change without 9.5 notice. 11.8 13.5 P 6.0 +0/-0.05 (.465) Users should verify actual device (.315) performance (.374) in their C specific applications. (.531) (.236 +0/-.002) 5.0 The products described herein and this document are subject A to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf 2 PLCS. DIA. (.197) . 2.2 +0.2/-0 6.5 2.5 (.087 +.008/-0) (.256) S W (.098)
18 TEETH
12.0
KNURLED
(.472) A C B 0.5 C 1.6 +0.2/-0 1.0 +0.1/-0 (.020) 0.5 (.063 +.008/-0) 3/8 ” (.039 +.004/-0) NEF (.020) 2.0 A C B A CHANNEL DIA. 5 PLCS. SWITCH (.079) 0.8 TRAVEL C COMMON (.032) 5.0 2.5 B CHANNEL (.197) (.098) 5.9 14.0 (.232) (.551) MOUNTING SURFACE 0.5 C (.020) 3/8 ” NEF 4.5 +0/-0.05 (.177 +0/-.002) DIA. 6.0 +0/-.0.05 F 9.5 (.236 +0/-.002) (.374) 0.5 (.020) SWITCH L TRAVEL MOUNTING SURFACE
