5 VDC 10K OHMS 10K OHMS 10K OHMS 10K OHMS TERMINAL A TERMINAL B 0.01 μF 0.01 μF ENCODER PEC11H Series - 11 mm Encoder w/High Detent Force TERMINAL C How To OrderSwitch CircuitPEC11H - 4 0 20 F - S 0020 Model Terminal Configuration 4 = PC Pin Horizontal/Rear Facing S W Detent Option 0 = 16 Detents (8, 16 pulses) 2 = 24 Detents (24 pulses) 1 = 20 Detents (20 pulses) 3 = 30 Detents (15 pulses) Suggested Filter Circuit Standard Shaft Length CW 5 VDC 15 = 15.0 mm 25 = 25.0 mm 20 = 20.0 mm 30 = 30.0 mm 10K OHMS 10K OHMS Shaft Style OFF F = Metal Flatted Shaft A Signal ON 10K OHMS 10K OHMS K = Metal Knurled Shaft Switch Configuration TERMINAL A TERMINAL B S = Push Momentary Switch B Signal 0.01 N = No Switch μF 0.01 μF D Resolution 0.75 ENCODER M7 x 0008 = 8 Pulses per 360 ° Rotation 0020 = 20 Pulses per 360 ° Rotation (.030) 0015 = 15 Pulses per 360 ° Rotation 0024 = 24 Pulses per 360 ° Rotation TERMINAL C 0016 = 16 Pulses per 360 ° Rotation 10.0 ± 0.5 2 ± 0.2 Hardware (.394 ± .020) (.079 ± .008) NUTQuadrature Output Table 12.0 ± 0.3 7.1 ± 0.3 CW 0.75 (.472 ± .012) DIA. (.280 ± .012) DIA. M7 x OFF (.030) A Signal ON 1 2 B Signal 10.0 ± 0.5 2 ± 0.2 0.5 D D (.394 ± .020) (.079 ± .008) CWWASHER (.020) NUTCCW 12.0 ± 0.3 7.1 ± 0.3 OFF (.472 ± .012) DIA. (.280 ± .012) DIA. A Signal ON B Signal D 0.5 WASHER (.020) 06/20 Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf.
