Datasheet HMC1030LP5E (Analog Devices) - 10
DescriptionDual RMS Power Detector SMT, Single-Ended, DC - 3.9 GHz
Pages / Page38 / 10 — HMC1030LP5E. DUAL RMS POWER DETECTOR. DC - 3.9 GHz. RMSA vs. Pin with …
File Format / SizePDF / 5.0 Mb
HMC1030LP5E. DUAL RMS POWER DETECTOR. DC - 3.9 GHz. RMSA vs. Pin with WCDMA 4 Carrier. RMSB Slope vs. Frequency [1]
HMC1030LP5E DUAL RMS POWER DETECTOR DC - 3.9 GHz RMSA vs Pin with WCDMA 4 Carrier RMSB Slope vs Frequency [1]
HMC1030LP5E
v03.1113
DUAL RMS POWER DETECTOR DC - 3.9 GHz RMSA vs. Pin with WCDMA 4 Carrier RMSB Slope vs. Frequency [1] @ +25 °C [1] [2]
60 3 55 100MHz 2.5 900MHz 1900MHz +25C 2200MHz 50 +85C 2 2700MHz -40C 3500MHz 3900MHz 45 1.5 RMSA (V) SLOPE (mV/dB) 40 1 35 0.5 30 11 0 1000 2000 3000 4000 0-70 -60 -50 -40 -30 -20 -10 0 10 FREQUENCY (MHz) INPUT POWER (dBm) T
RMSB vs. Pin with WCDMA 4 Carrier RMSA Error vs. Pin with WCDMA 4 Carrier
M
@ +25 °C [1] [2] @ +25 °C [1] [2]
S 3 4 - 100MHz 3 2.5 900MHz 1900MHz RS 2200MHz 2 2 2700MHz O 3500MHz 1 3900MHz T 1.5 0 C RMSB (V) ERROR (dB) -1 1 100MHz TE 900MHz -2 1900MHz E 2200MHz 0.5 2700MHz -3 3500MHz D 3900MHz 0 -4 R -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) WE
RMSB Error vs. Pin with WCDMA 4 RMSA Error vs. Pin with WCDMA 4 Carrier
O
Carrier @ +25 °C [1] [2] @ +85 °C wrt +25 °C Response [1] [2]
P 4 4 3 3 100MHz 900MHz 1900MHz 2 2 2200MHz 2700MHz 1 1 3500MHz 3900MHz 0 0 ERROR (dB) -1 ERROR (dB) -1 100MHz 900MHz -2 1900MHz -2 2200MHz 2700MHz -3 3500MHz -3 3900MHz -4 -4 -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) [1] WCDMA Input Waveform [2] SCA1=SCA3=SCB1=SCB3=0V, SCA2=SCB2=5V Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
11 - 10
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
