Datasheet ADL5505 (Analog Devices) - 9
Description450 MHz TO 6000 MHz TruPwr Detector
Pages / Page20 / 9 — ADL5505. R (. RRO. –25. –20. –15. –10. INPUT (dBm)
ADL5505 R ( RRO –25 –20 –15 –10 INPUT (dBm)
ADL5505 3 3 2 2 1 1 B) B) d d R ( 0 R ( 0 RRO RRO E E –1 –1 –2 –2 –3 –3 –25 –20 –15 –10 –5 0 5 10 15
010
013
INPUT (dBm) INPUT (dBm)
05799- 05799- Figure 10. Output Temperature Drift from +25°C Linear Reference Figure 13. Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C; Frequency = 450 MHz 50 Devices at −40°C and +85°C; Frequency = 450 MHz
011
014
05799- 05799- Figure 11. Output Temperature Drift from +25°C Linear Reference Figure 14. Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C; Frequency = 900 MHz 50 Devices at −40°C and +85°C; Frequency = 900 MHz
012
015
INPUT (dBm)
05799-
INPUT (dBm)
05799- Figure 12. Output Temperature Drift from +25°C Linear Reference Figure 15. Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C; Frequency = 1900 MHz 50 Devices at −40°C and +85°C; Frequency = 1900 MHz Rev. A | Page 9 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description RMS Circuit Description and Filtering Filtering Output Buffer Applications Information Basic Connections RF Input Interfacing Resistive Tap RF Input Multiple RF Inputs Linearity Output Swing Output Offset Output Drive Capability and Buffering Selecting the Output Low-Pass Filter Power Consumption Device Calibration and Error Calculation Calibration for Improved Accuracy Drift Over a Reduced Temperature Range Device Handling Land Pattern and Soldering Information Evaluation Board Outline Dimensions Ordering Guide
