Datasheet ADL5505 (Analog Devices) - 10
Description450 MHz TO 6000 MHz TruPwr Detector
Pages / Page20 / 10 — ADL5505. R (. RRO. –25. –20. –15. –10. INPUT (dBm)
ADL5505 R ( RRO –25 –20 –15 –10 INPUT (dBm)
ADL5505 3 3 2 2 1 1 B) B) d d R ( 0 R ( 0 RRO RRO E E –1 –1 –2 –2 –3 –3 –25 –20 –15 –10 –5 0 5 10 15
016
019
INPUT (dBm) INPUT (dBm)
05799- 05799- Figure 16. Output Temperature Drift from +25°C Linear Reference Figure 19. Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C; Frequency = 2600 MHz 50 Devices at −40°C and +85°C; Frequency = 2600 MHz
017
020
05799- 05799- Figure 17. Output Temperature Drift from +25°C Linear Reference Figure 20. Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C; Frequency = 3500 MHz 50 Devices at −40°C and +85°C; Frequency = 3500 MHz
3 3 2 2 1 1 B) B) d d R ( 0 R ( 0 RRO RRO E E –1 –1 –2 –2 –3 –3 –25 –20 –15 –10 –5 0 5 10 15 –25 –20 –15 –10 –5 0 5 10 15
018 021
05799- 05799- Figure 18. Output Temperature Drift from +25°C Linear Reference Figure 21. Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C; Frequency = 6000 MHz 50 Devices at −40°C and +85°C; Frequency = 6000 MHz Rev. A | Page 10 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description RMS Circuit Description and Filtering Filtering Output Buffer Applications Information Basic Connections RF Input Interfacing Resistive Tap RF Input Multiple RF Inputs Linearity Output Swing Output Offset Output Drive Capability and Buffering Selecting the Output Low-Pass Filter Power Consumption Device Calibration and Error Calculation Calibration for Improved Accuracy Drift Over a Reduced Temperature Range Device Handling Land Pattern and Soldering Information Evaluation Board Outline Dimensions Ordering Guide
