Datasheet HMC1010LP4E (Analog Devices) - 9
DescriptionRMS Power Detector SMT, DC - 3.9 GHz
Pages / Page24 / 9 — HMC1010LP4E. RMS POWER DETECTOR. DC - 3.9 GHz. Absolute Maximum Ratings. …
File Format / SizePDF / 2.8 Mb
HMC1010LP4E. RMS POWER DETECTOR. DC - 3.9 GHz. Absolute Maximum Ratings. Outline Drawing. Package Information. 11 - 9
HMC1010LP4E RMS POWER DETECTOR DC - 3.9 GHz Absolute Maximum Ratings Outline Drawing Package Information 11 - 9
HMC1010LP4E
v03.0511
Supply Voltage (Vcc) 5.6V eLectrostAtIc seNsItIVe DeVIce rF Input Power 16 dBm oBserVe HANDLING PrecAUtIoNs Differential Input Voltage 1.6 Vp-p channel / Junction temperature 125 °c Continuous Pdiss (T = 85°C) 1.39 w (Derate 34.87 mW/°c above 85°C) Thermal Resistance (R ) th 28.68 °c/w (junction to ground paddle) 11 storage temperature -65 to +150 °c operating temperature -40 to +85 °c ESD Sensitivity (HBM) class 1B t
Outline Drawing
M s - rs o t c e t e D r e w o P Notes: 1. LeADFrAMe MAterIAL: coPPer ALLoY 2. DIMeNsIoNs Are IN INcHes [MILLIMeters]. 3. LeAD sPAcING toLerANce Is NoN-cUMULAtIVe 4. PAD BUrr LeNGtH sHALL Be 0.15mm MAXIMUM. PAD BUrr HeIGHt sHALL Be 0.05mm MAXIMUM. 5. PAcKAGe wArP sHALL Not eXceeD 0.05mm. 6. ALL GroUND LeADs AND GroUND PADDLe MUst Be soLDereD to PcB rF GroUND. 7. reFer to HMc APPLIcAtIoN Note For sUGGesteD PcB LAND PAtterN.
Package Information
Part Number Package Body Material Lead Finish MsL rating Package Marking [1] HMc1010LP4e roHs-compliant Low stress Injection Molded Plastic 100% matte sn MsL1 [2] H1010 XXXX [1] 4-Digit lot number XXXX [2] Max peak reflow temperature of 260 °c Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
11 - 9
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
