Datasheet AD8361 (Analog Devices) - 8
Description | LF to 2.5 GHz TruPwr Detector |
Pages / Page | 22 / 8 — AD8361. Data Sheet. 0.03. 0.18. 0.16. 0.02. 0.14. 0.01. 0.12. 0.10. 0.00. … |
Revision | F |
File Format / Size | PDF / 507 Kb |
AD8361. Data Sheet. 0.03. 0.18. 0.16. 0.02. 0.14. 0.01. 0.12. 0.10. 0.00. MEAN. 3 SIGMA. 0.08. –0.01. 0.06. 0.04. –0.02. INTERCEPT CHANGE (V) –0.03
AD8361 Data Sheet 0.03 0.18 0.16 0.02 0.14 0.01 0.12 0.10 0.00 MEAN
3 SIGMA 0.08 –0.01 0.06 0.04 –0.02 0.02 MEAN
3 SIGMA INTERCEPT CHANGE (V) –0.03 GAIN CHANGE (V/V rms) 0.00 –0.02 –0.04 –0.04 –0.05 –0.06 –40 –20 0 20 40 60 80 100 –40 –20 0 20 40 60 80 100 TEMPERATURE (°C)
01088-C-018
TEMPERATURE (°C)
01088-C-021 Figure 18. Output Reference Change vs. Temperature, Figure 21. Conversion Gain Change vs. Temperature, Supply 3 V, Supply 3 V, Ground Reference Mode Ground Reference Mode, Frequency 900 MHz
0.02 0.18 0.16 0.14 0.01 0.12 0.10 MEAN
3 SIGMA 0.00 0.08 0.06 0.04 –0.01 0.02 MEAN
3 SIGMA INTERCEPT CHANGE (V) GAIN CHANGE (V/V rms) 0.00 –0.02 –0.02 –0.04 –0.03 –0.06 –40 –20 0 20 40 60 80 100 –40 –20 0 20 40 60 80 100 TEMPERATURE (°C)
01088-C-019
TEMPERATURE (°C)
01088-C-022 Figure 19. Output Reference Change vs. Temperature, Supply 3 V, Figure 22. Conversion Gain Change vs. Temperature, Supply 3 V, Internal Reference Mode (MSOP Only) Internal Reference Mode, Frequency 900 MHz (MSOP Only)
3 SIGMA 0.08 –0.01 0.06 0.04 –0.02 MEAN
3 SIGMA 0.02 INTERCEPT CHANGE (V) –0.03 GAIN CHANGE (V/V rms) 0.00 –0.02 –0.04 –0.04 –0.05 –0.06 –40 –20 0 20 40 60 80 100 –40 –20 0 20 40 60 80 100 TEMPERATURE (°C)
01088-C-020
TEMPERATURE (°C)
01088-C-023 Figure 20. Output Reference Change vs. Temperature, Supply 3 V, Figure 23. Conversion Gain Change vs. Temperature, Supply 3 V, Supply Reference Mode (MSOP Only) Supply Reference Mode, Frequency 900 MHz (MSOP Only) Rev. F | Page 8 of 22 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION Filtering Offset APPLICATION INFORMATION Basic Connections Output Swing Dynamic Range Input Coupling and Matching Input Coupling Using a Series Resistor Selecting the Filter Capacitor Operation at Low Frequencies Power Consumption, Enable and Power-On Volts to dBm Conversion Output Drive Capability and Buffering OUTPUT REFERENCE TEMPERATURE DRIFT COMPENSATION Extended Frequency Characterization EVALUATION BOARD CHARACTERIZATION SETUPS Equipment Analysis OUTLINE DIMENSIONS ORDERING GUIDE
