Datasheet ADRV9002 (Analog Devices) - 9
Description | Dual Narrow/Wideband RF Transceiver |
Pages / Page | 71 / 9 — Preliminary Technical Data. ADRV9002. Parameter. Symbol Min. Typ Max … |
Revision | PrA |
File Format / Size | PDF / 1.6 Mb |
Preliminary Technical Data. ADRV9002. Parameter. Symbol Min. Typ Max Units. Test. Conditions/Comments
Preliminary Technical Data ADRV9002 Parameter Symbol Min Typ Max Units Test Conditions/Comments
Narrow-Band LB − Low power receiver ADCs, 0 dB receiver attenuation, f1dB IIP3DIFF of TIA = 2 MHz, two continuous wave tones at 100 kHz and 150 kHz, FSIP − 12 dB/tone. 30 MHz 20 dBm 470 MHz 19 dBm 900 MHz 18 dBm 2400 MHz 15 dBm 3500 MHz 14 dBm 5800 MHz 13 dBm THIRD-ORDER HARMONIC DISTORTION Wideband HD3WB High performance receiver ADCs, FSIP − 7 dB continuous wave tone at 5.6 MHz, f1dB of TIA = 20 MHz, HD3 product at 16.8 MHz. 30 MHz −85 dBc The RF source is low-pass filtered before DUT. 470 MHz −75 dBc 900 MHz −82 dBc 2400 MHz −90 dBc 3500 MHz −90 dBc 5800 MHz −89 dBc Narrow-Band HD3LB High performance receiver ADCs, FSIP − 7 dB continuous wave tone at 34 kHz, f1dB of TIA = 2 MHz, HD3 product at 102 kHz. 30 MHz −100 dBc 470 MHz −99 dBc 900 MHz −93 dBc 2400 MHz −95 dBc 3500 MHz −96 dBc 5800 MHz −94 dBc Wideband HD3WB Low power receiver ADCs, FSIP − 7 dB continuous wave tone at 5.6 MHz, f1dB of TIA = 20 MHz, HD3 product at 16.8 MHz. 30 MHz −80 dBc RF source low-pass filtered before DUT. 470 MHz −74 dBc 900 MHz −76 dBc 2400 MHz −82 dBc 3500 MHz −78 dBc 5800 MHz −80 dBc Narrow-Band HD3LB Low power receiver ADCs, FSIP − 7 dB continuous wave tone at 34 kHz, f1dB of TIA = 2 MHz, HD3 product at 102 kHz. 30 MHz TBD dBc 470 MHz −85 dBc 900 MHz −76 dBc 2400 MHz −78 dBc 3500 MHz −75 dBc 5800 MHz −74 dBc SECOND-ORDER HARMONIC DISTORTION Wideband HD2WB High performance receiver ADCs, FSIP − 7 dB continuous wave tone at 5.6 MHz, f1dB of TIA = 20 MHz, HD2 product at 11.2 MHz. 30 MHz −90 dBc 470 MHz −90 dBc 900 MHz −88 dBc Rev. PrA | Page 9 of 71 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS TRANSMITTER SPECIFICATIONS RECEIVER SPECIFICATIONS INTERNAL LO, EXTERNAL LO, AND DEVICE CLOCK DIGITAL INTERFACES AND AUXILIARY CONVERTERS POWER SUPPLY SPECIFICATIONS CURRENT CONSUMPTION ESTIMATES (TYPICAL VALUES) Sleep Mode (Typical Values) TDD Operation (Typical Values) FDD Operation (Typical Values) TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS REFLOW PROFILE THERMAL RESISTANCE ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD Ratings for ADRV2009 ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 30 MHZ BAND 470 MHZ BAND 900 MHZ BAND 2400 MHZ BAND 3500 MHZ BAND 5800 MHZ BAND PHASE NOISE THEORY OF OPERATION TRANSMITTER RECEIVER Monitor Mode DPD Receiver as an Observation Receiver CLOCK INPUT SYNTHESIZERS RF PLL Baseband PLL (PLL) SPI INTERFACE GPIO PINS Digital GPIO Inputs/Outputs (DGPIO) Analog GPIO Inputs/Outputs (AGPIO) AUXILLARY CONVERTERS Auxiliary ADC Inputs (AUXADC_x) Auxiliary DACs Outputs (AUXDAC_x) JTAG BOUNDARY SCAN APPLICATIONS INFORMATION POWER SUPPLY SEQUENCE DIGITAL DATA INTERFACE CSSI CSSI Receive CSSI Transmit LSSI OUTLINE DIMENSIONS
