Datasheet ADRV9008-2 (Analog Devices) - 2
DescriptionIntegrated Dual RF Transmitter and Observation Receiver
Pages / Page95 / 2 — ADRV9008-2. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY …
ADRV9008-2. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 9/2018—Revision 0: Initial Version
ADRV9008-2 Data Sheet TABLE OF CONTENTS REVISION HISTORY 9/2018—Revision 0: Initial Version
link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 4 link to page 13 link to page 14 link to page 15 link to page 15 link to page 15 link to page 15 link to page 15 link to page 16 link to page 23 link to page 23 link to page 36 link to page 47 link to page 57 link to page 67 link to page 67 link to page 68 link to page 69 link to page 69 link to page 69 link to page 69 link to page 69 link to page 69 link to page 69 link to page 69 link to page 70 link to page 70 link to page 70 link to page 71 link to page 71 link to page 71 link to page 73 link to page 74 link to page 79 link to page 83 link to page 85 link to page 95 link to page 95
Features .. 1 Theory of Operation .. 69 Applications ... 1 Transmitter .. 69 General Description ... 1 Observation Receiver ... 69 Revision History ... 2 Clock Input .. 69 Functional Block Diagram .. 3 Synthesizers ... 69 Specifications ... 4 Serial Peripheral Interface (SPI) ... 69 Current and Power Consumption Specifications ... 13 JTAG Boundary Scan ... 69 Timing Diagrams .. 14 Power Supply Sequence ... 69 Absolute Maximum Ratings .. 15 GPIO_x Pins ... 70 Reflow Profile .. 15 Auxiliary Converters .. 70 Thermal Management ... 15 JESD204B Data Interface .. 70 Thermal Resistance .. 15 Applications Information .. 71 ESD Caution .. 15 PCB Layout and Power Supply Recommendations ... 71 Pin Configuration and Function Descriptions ... 16 PCB Material and Stackup Selection ... 71 Typical Performance Characteristics ... 23 Fanout and Trace Space Guidelines ... 73 75 MHz to 525 MHz Band .. 23 Component Placement and Routing Guidelines ... 74 650 MHz to 3000 MHz Band .. 36 RF and JESD204B Transmission Line Layout .. 79 3400 MHz to 4800 MHz Band .. 47 Isolation Techniques Used on the ADRV9008-2W/PCBZ ... 83 5100 MHz to 5900 MHz Band .. 57 RF Port Interface Information .. 85 Transmitter Output Impedance .. 67 Outline Dimensions ... 95 Observation Receiver Input Impedance .. 67 Ordering Guide .. 95 Terminology .. 68
Rev. 0 | Page 2 of 95 Document Outline Features Applications General Description Revision History Functional Block Diagram Specifications Current and Power Consumption Specifications Timing Diagrams Absolute Maximum Ratings Reflow Profile Thermal Management Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 75 MHz to 525 MHz Band 650 MHz to 3000 MHz Band 3400 MHz to 4800 MHz Band 5100 MHz to 5900 MHz Band Transmitter Output Impedance Observation Receiver Input Impedance Terminology Theory of Operation Transmitter Observation Receiver Clock Input Synthesizers RF PLL Clock PLL Serial Peripheral Interface (SPI) JTAG Boundary Scan Power Supply Sequence GPIO_x Pins Auxiliary Converters AUXADC_x Auxiliary DAC x JESD204B Data Interface Applications Information PCB Layout and Power Supply Recommendations Overview PCB Material and Stackup Selection Fanout and Trace Space Guidelines Component Placement and Routing Guidelines Signals with Highest Routing Priority Signals with Second Routing Priority Signals with Lowest Routing Priority RF and JESD204B Transmission Line Layout RF Routing Guidelines Transmitter Balun DC Feed Supplies JESD204B Trace Routing Recommendations Routing Recommendations Stripline Transmission Lines vs. Microstrip Transmission Lines Isolation Techniques Used on the ADRV9008-2W/PCBZ Isolation Goals Isolation Between JESD204B Lines RF Port Interface Information RF Port Impedance Data Advanced Design System (ADS) Setup Using the DataAccessComponent and SEDZ File Transmitter Bias and Port Interface General Observation Receiver Path Interface Impedance Matching Network Example Outline Dimensions Ordering Guide
