Datasheet HMC8200LP5ME (Analog Devices)
Description | Intermediate Frequency Transmitter 800 MHz to 4000 MHz |
Pages / Page | 25 / 1 — Intermediate Frequency Transmitter,. 800 MHz to 4000 MHz. Data Sheet. … |
Revision | D |
File Format / Size | PDF / 617 Kb |
Intermediate Frequency Transmitter,. 800 MHz to 4000 MHz. Data Sheet. HMC8200LP5ME. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Intermediate Frequency Transmitter, 800 MHz to 4000 MHz Data Sheet HMC8200LP5ME FEATURES FUNCTIONAL BLOCK DIAGRAM High linearity: supports modulations to 1024 QAM HMC8200 Tx IF range: 200 MHz to 700 MHz RM NV Tx RF range: 800 MHz to 4000 MHz K P N _P DI CL CC_I CC_E NV Tx power control: 25 dB S S SEN LO_ LO_ V V E SPI controlled interface 32 31 30 29 28 27 26 25 32-lead, 5 mm × 5 mm LFCSP package SDO 1 24 ENV_N 2 APPLICATIONS DVDD SPI 23 D2S_OUT RST 3 22 VCC_D2S Point to point communications BB_IP 4 21 VVA_IN Satellite communications BB_IN 5 20 VGA_VCTRL Wireless microwave backhaul systems VCC_DGA 6 19 VCC_VGA BB_QN 7 18 TX_OUT BB_QP 8 BAND 17 VCC_AMP GAP 9 10 11 12 13 14 15 16 PACKAGE N IF F G BASE UT UT R IFIN O _ 2_I 1_O TX D_O CC_BG A_S LOG_ P V LOG_ CC_L L
001
A_S V DG S DG
13868- Figure 1.
GENERAL DESCRIPTION
With IF input power ranges from −31 dBm to +4 dBm, the The HMC8200LP5ME is a highly integrated intermediate HMC8200LP5ME provides 35 dB of digital gain control in 1 dB frequency (IF) transmitter chip that converts the industry steps and an analog voltage gain amplifier (VGA) continuously standard 300 MHz to 400 MHz IF input signals to an 800 MHz to controls the transmitter output power from −20 dBm to +5 dBm. 4000 MHz single-ended radio frequency (RF) signal at its output. The device also features three integrated power detectors. The The IF transmitter chip is housed in a compact 5 mm × 5 mm first detector (LOG_IF) can be utilized to monitor the IF input LFCSP package and supports complex modulations up to power. The second detector (SLPD_OUT) is a square law power 1024 QAM. The HMC8200LP5ME simultaneously reduces the detector that monitors the power entering the mixer. The third design complexity of traditional microwave radios while realizing power detector (LOG_RF) is used to monitor the output power, significant size and cost improvements. which can be used for fine output power adjustment.
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2016–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Characteristics: 800 MHz to 1800 MHz RF Frequency Range Electrical Characteristics: 1800 MHz to 2800 MHz RF Frequency Range Electrical Characteristics: 2800 MHz to 4000 MHz RF Frequency Range Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Register Array Assignments and Serial Interface Read Example Register Descriptions Register Array Assignments Enable Bits Digital Gain Amplifier: DGA Control Digital Gain Amplifier: Amplifier Current, Envelope Level, and VGA Attenuation Bias Image Reject Mixer: Sideband, and Polarity and Offset for I Image Reject Mixer: Polarity and Offset for Q Phase I: Adjust Phase Q: Adjust Evaluation Printed Circuit Board (PCB) Evaluation PCB Schematic Outline Dimensions Ordering Guide
