Datasheet ADF4602 (Analog Devices) - 7
DescriptionSingle-Chip, Multiband 3G Femtocell Transceiver
Pages / Page36 / 7 — ADF4602. Parameter. Min. Typ. Max. Unit. Test Conditions
RevisionA
File Format / SizePDF / 662 Kb
ADF4602 Parameter Min Typ Max Unit Test Conditions
POWER SUPPLIES Voltage Supply VDD 3.1 3.3 3.6 V Main supply input VSUP1 2.6 V Output from internal LDO1, 10 mA rating, supply for RX VCO VSUP2 2.8 V Output from Internal LDO2, 30 mA rating, supply for RX baseband and RX down- converter VSUP3 1.9 V Output from internal LDO3, 10 mA rating, supply for RX LNAs VSUP4 2.6 V Output from internal LDO4, 10 mA rating, supply for TX VCO VSUP5 2.8 V Output from internal LDO5, 100 mA rating, supply for TX modulator, TX baseband, PA control DACs VSUP6 1.9 V Supply input for RX synthesizer, connect to VSUP3 VSUP7 1.9 V Supply input for TX synthesizer, connect to VSUP3 VSUP8 2.8 V Supply input for reference section, connect to VSUP2 VINT 1.6 1.8 2.0 V Supply input for serial interface control logic CURRENT CONSUMPTION Transmit Current Consumption VDD = 3.6 V, output is matched into 50 Ω −8 dBm Output Level 100 mA FRF = 2170 MHz −28 dBm Output Level 50 mA FRF = 2170 MHz Receive Current Consumption 50 mA 1 The reference frequency should be dc coupled to the REFIN pin. It is ac-coupled internally. 2 The noise figure measurement does not include spurious noise due to harmonics of the 26 MHz reference frequency. Spurs appear at integer multiples of the reference frequency (every 26 MHz), degrading the receive sensitivity by about 6 dB. 3 Guaranteed by design, not production tested. 4 Bit sif_vsup8 in Register 2 controls whether 1.8 V readback mode or 2.8 V readback mode is selected. See the Serial Port Interface (S sect PI) ion for more details. Rev. A | Page 7 of 36 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION TRANSMITTER DESCRIPTION I/Q Baseband I/Q Modulator VCO Output TX Output Baluns DACS GENERAL PURPOSE OUTPUTS RECEIVER DESCRIPTION LNAs Mixers Baseband Section Gain Control DC Offset Compensation POWER MANAGEMENT FREQUENCY SYNTHESIS Reference Path SERIAL PORT INTERFACE (SPI) Format OPERATION AND TIMING Read REGISTERS REGISTER MAP REGISTER DESCRIPTION SOFTWARE INITIALIZATION PROCEDURE INITIALIZATION SEQUENCE Nonvolatile Memory (NVM) Initialization Programming Transmit and Receive frequencies APPLICATIONS INFORMATION INTERFACING THE ADF4602 TO THE AD9963 AD9963 ADC Inputs Interfacing to the AD9963 Rx Baseband Inputs AD9963 DAC Outputs Reference Voltage Current Scaling Resistor, RSET Gain Scaling Parameters RECEIVE SENSITIVITY Interfacing to the AD9963 TX Baseband Outputs OUTLINE DIMENSIONS ORDERING GUIDE
