Datasheet TLP170GM (Toshiba) - 4
Manufacturer | Toshiba |
Description | Photocouplers Photorelay |
Pages / Page | 10 / 4 — TLP170GM. 8. Electrical. Characteristics. (Unless. otherwise. specified,. … |
File Format / Size | PDF / 305 Kb |
TLP170GM. 8. Electrical. Characteristics. (Unless. otherwise. specified,. Ta. =. 25. ). Characteristics. Symbol. Note. Test. Condition. Min. Typ. Max. Unit
TLP170GM 8. Electrical Characteristics (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Test Condition Min Typ. Max Unit LED Input forward voltage VF IF = 10 mA 1.1 1.27 1.4 V Input reverse current IR VR = 5 V 10 µA Input capacitance Ct V = 0 V, f = 1 MHz 30 pF Detector OFF-state current IOFF VOFF = 350 V 0.001 1 µA Output capacitance COFF V = 0 V, f = 1 MHz 30 pF 9. Coupled Electrical Characteristics (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Test Condition Min Typ. Max Unit Trigger LED current IFT ION = 110 mA 0.2 1 mA Return LED current IFC IOFF = 100 µA 0.01 0.2 mA ON-state resistance RON ION = 110 mA, IF = 2 mA, t < 1 s 22 35 Ω ION = 110 mA, IF = 2 mA 28 50 10. Isolation Characteristics (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Test Condition Min Typ. Max Unit Total capacitance (input to output) CS (Note 1) VS = 0 V, f = 1 MHz 0.8 pF Isolation resistance RS (Note 1) VS = 500 V, R.H. ≤ 60 % 5 × 1010 1014 Ω Isolation voltage BVS (Note 1) AC, 60 s 3750 Vrms Note 1: This device is considered as a two-terminal device: Pins 1 and 3 are shorted together, and pins 4 and 6 are shorted together. 11. Switching Characteristics (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Test Condition Min Typ. Max Unit Turn-on time tON See Fig. 11.1 1 2 ms RL = 200 Ω, VDD = 20 V, IF = 2 mA Turn-off time tOFF 0.5 1 Fig. 11.1 Switching Time Test Circuit and Waveform ©2020 4 2020-05-13 Toshiba Electronic Devices & Storage Corporation Rev.1.0
