Datasheet ADCMP394, ADCMP395, ADCMP396 (Analog Devices) - 5
DescriptionDual Comparator with Accurate Reference Output
Pages / Page18 / 5 — Data Sheet. ADCMP394/ADCMP395/ADCMP396. PIN CONFIGURATIONS AND FUNCTION …
File Format / SizePDF / 412 Kb
Data Sheet. ADCMP394/ADCMP395/ADCMP396. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. GND 1. 8 OUT. NIC 2. ADCMP394. VCC. IN+ 3. TOP VIEW
Data Sheet ADCMP394/ADCMP395/ADCMP396 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS GND 1 8 OUT NIC 2 ADCMP394 VCC IN+ 3 TOP VIEW
Data Sheet ADCMP394/ADCMP395/ADCMP396 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS GND 1 8 OUT NIC 2 7 ADCMP394 VCC IN+ 3 TOP VIEW 6 REF (Not to Scale) IN– 4 5 NIC
002
NOTES 1. NIC = NOT INTERNALLY CONNECTED.
12209- Figure 4. ADCMP394 Pin Configuration
Table 4. ADCMP394 Pi n Function Descriptions Pin No. Mnemonic Description
1 GND Device Ground. 2, 5 NIC Not Internally Connected. 3 IN+ Comparator Noninverting Input. 4 IN− Comparator Inverting Input. 6 REF Reference Output. This pin can be used to setup the comparator threshold. 7 VCC Device Supply Input. 8 OUT Comparator Output, Open-Drain.
OUTA 1 10 OUTB VCC 2 ADCMP395 9 GND INA– 3 TOP VIEW 8 INB– (Not to Scale) INA+ 4 7 INB+ NIC 5 6 REF
05 2 9-
1220 Figure 5. ADCMP395 Pin Configuration
Table 5. ADCMP395 Pi n Function Descriptions Pin No. Mnemonic Description
1 OUTA Comparator A Output, Open Drain. 2 VCC Device Supply Input. 3 INA− Comparator A Inverting Input. 4 INA+ Comparator A Noninverting Input. 5 NIC Not Internally Connected. 6 REF Reference Output. This pin can be used to set up comparator threshold. 7 INB+ Comparator B Noninverting Input. 8 INB− Comparator B Inverting Input. 9 GND Device Ground. 10 OUTB Comparator B Output, Open Drain. Rev. B | Page 5 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENT REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC COMPARATOR RAIL-TO-RAIL INPUT (RRI) OPEN-DRAIN OUTPUT POWER-UP BEHAVIOR CROSSOVER BIAS POINT COMPARATOR HYSTERESIS TYPICAL APPLICATIONS ADDING HYSTERESIS WINDOW COMPARATOR FOR POSITIVE VOLTAGE MONITORING WINDOW COMPARATOR FOR NEGATIVE VOLTAGE MONITORING PROGRAMMABLE SEQUENCING CONTROL CIRCUIT MIRRORED VOLTAGE SEQUENCER EXAMPLE THRESHOLD AND TIMEOUT PROGRAMMABLE VOLTAGE SUPERVISOR OUTLINE DIMENSIONS ORDERING GUIDE
