Datasheet ADCMP394, ADCMP395, ADCMP396 (Analog Devices) - 6
DescriptionDual Comparator with Accurate Reference Output
Pages / Page18 / 6 — ADCMP394/ADCMP395/ADCMP396. Data Sheet. OUTB 1. 16 OUTC. OUTA 2. 15 OUTD. …
RevisionB
File Format / SizePDF / 412 Kb
ADCMP394/ADCMP395/ADCMP396. Data Sheet. OUTB 1. 16 OUTC. OUTA 2. 15 OUTD. VCC 3. 14 GND. INA– 4. ADCMP396 13 IND+. TOP VIEW. INA+ 5. 12 IND–
ADCMP394/ADCMP395/ADCMP396 Data Sheet OUTB 1 16 OUTC OUTA 2 15 OUTD VCC 3 14 GND INA– 4 ADCMP396 13 IND+ TOP VIEW INA+ 5 12 IND–
ADCMP394/ADCMP395/ADCMP396 Data Sheet OUTB 1 16 OUTC OUTA 2 15 OUTD VCC 3 14 GND INA– 4 ADCMP396 13 IND+ TOP VIEW INA+ 5 12 IND– (Not to Scale) INB– 6 11 INC+ INB+ 7 10 INC– NIC 8 9 REF
206
NIC = NOT INTERNALLY CONNECTED.
2209-1 Figure 6. ADCMP396 Pin Configuration
Table 6. ADCMP396 Pi n Function Descriptions Pin No. Mnemonic Description
1 OUTB Comparator B Output, Open Drain. 2 OUTA Comparator A Output, Open Drain. 3 VCC Device Supply Input. 4 INA− Comparator A Inverting Input. 5 INA+ Comparator A Noninverting Input. 6 INB− Comparator B Inverting Input. 7 INB+ Comparator B Noninverting Input. 8 NIC Not Internally Connected. 9 REF Reference Output. This pin can be used to set up the comparator threshold. 10 INC− Comparator C Inverting Input. 11 INC+ Comparator C Noninverting Input. 12 IND− Comparator D Inverting Input. 13 IND+ Comparator D Noninverting Input. 14 GND Device Ground. 15 OUTD Comparator D Output, Open Drain. 16 OUTC Comparator C Output, Open Drain. Rev. B | Page 6 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENT REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC COMPARATOR RAIL-TO-RAIL INPUT (RRI) OPEN-DRAIN OUTPUT POWER-UP BEHAVIOR CROSSOVER BIAS POINT COMPARATOR HYSTERESIS TYPICAL APPLICATIONS ADDING HYSTERESIS WINDOW COMPARATOR FOR POSITIVE VOLTAGE MONITORING WINDOW COMPARATOR FOR NEGATIVE VOLTAGE MONITORING PROGRAMMABLE SEQUENCING CONTROL CIRCUIT MIRRORED VOLTAGE SEQUENCER EXAMPLE THRESHOLD AND TIMEOUT PROGRAMMABLE VOLTAGE SUPERVISOR OUTLINE DIMENSIONS ORDERING GUIDE
