Datasheet ADCMP394, ADCMP395, ADCMP396 (Analog Devices) - 7
DescriptionDual Comparator with Accurate Reference Output
Pages / Page18 / 7 — Data Sheet. ADCMP394/ADCMP395/ADCMP396. TYPICAL PERFORMANCE …
File Format / SizePDF / 412 Kb
Data Sheet. ADCMP394/ADCMP395/ADCMP396. TYPICAL PERFORMANCE CHARACTERISTICS. 2.5. SAMPLE 1. TA = +25°C. 2.0. SAMPLE 2. TA = +85°C
Data Sheet ADCMP394/ADCMP395/ADCMP396 TYPICAL PERFORMANCE CHARACTERISTICS 2.5 SAMPLE 1 TA = +25°C 2.0 SAMPLE 2 TA = +85°C
Data Sheet ADCMP394/ADCMP395/ADCMP396 TYPICAL PERFORMANCE CHARACTERISTICS 2.5 2.5 SAMPLE 1 TA = +25°C 2.0 SAMPLE 2 2.0 TA = +85°C SAMPLE 3 TA = +125°C 1.5 V) 1.5 V) TA = –40°C (m (m E 1.0 E 1.0 G G A A T 0.5 T L 0.5 L VO 0 VO 0 SET SET F –0.5 F –0.5 F F O O T –1.0 T –1.0 PU PU IN –1.5 IN –1.5 –2.0 –2.0 –2.5 –2.5 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5
207
2.3 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5
210 9- 9-
COMMON-MODE VOLTAGE (V) SUPPLY VOLTAGE (V)
1220 1220 Figure 7. Input Offset Voltage (VOS) vs. Common-Mode Voltage (VCM), Figure 10. Input Offset Voltage (VOS) vs. Supply Voltage (VCC), VCM = 1 V VCC = 3.3 V for Various Temperatures
2.5 2.4 VCC = 2.3V IN+ = IN– + 10mV 2.0 V 2.2 CC = 3.3V VCM = IN– = 1V V ) CC = 5.5V 2.0 1.5 V m 1.8 ( 1.0 (V) GE 1.6 E 0.5 G LTA A 1.4 O T L V 0 T 1.2 E VO T –0.5 1.0 FFS PU T 0.8 T O –1.0 U U O P 0.6 IN –1.5 0.4 –2.0 0.2 –2.5 0
1
–40 –25 –10 5 20 35 50 65 80 95 110 125
1 208
0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2
2 9- 9-
TEMPERATURE (°C) SUPPLY VOLTAGE (V)
1220 1220 Figure 8. Input Offset Voltage (VOS) vs. Temperature for Figure 11. Output Voltage (VOUT) vs. Supply Voltage (VCC), RPULLUP = 10 kΩ Various Supply Voltages, VCM = 1 V
70 70 ADCMP394 ADCMP394 ADCMP395 ADCMP395 65 ADCMP396 65 ADCMP396 60 60 A) µ A) ( 55 55 (u NT NT 50 50 RRE RRE CU 45 CU 45 Y L LY P P P 40 40 U UP S S 35 35 30 30 25
9
25 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5
20
12 2
SUPPLY VOLTAGE (V)
2209- 1
SUPPLY VOLTAGE (V)
2209- 1 Figure 9. Supply Current (ICC) vs. Supply Voltage (VCC) at Output Low Voltage Figure 12. Supply Current (ICC) vs. Supply Voltage (VCC) at Output High Voltage Rev. B | Page 7 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENT REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC COMPARATOR RAIL-TO-RAIL INPUT (RRI) OPEN-DRAIN OUTPUT POWER-UP BEHAVIOR CROSSOVER BIAS POINT COMPARATOR HYSTERESIS TYPICAL APPLICATIONS ADDING HYSTERESIS WINDOW COMPARATOR FOR POSITIVE VOLTAGE MONITORING WINDOW COMPARATOR FOR NEGATIVE VOLTAGE MONITORING PROGRAMMABLE SEQUENCING CONTROL CIRCUIT MIRRORED VOLTAGE SEQUENCER EXAMPLE THRESHOLD AND TIMEOUT PROGRAMMABLE VOLTAGE SUPERVISOR OUTLINE DIMENSIONS ORDERING GUIDE
