Datasheet ADCMP671 (Analog Devices) - 10
Description | Low Power Adjustable UV and OV Monitor with 400 mV 0.275% Reference |
Pages / Page | 16 / 10 — ADCMP671. Data Sheet. 12.0. 11.5. 1NH1. VDD = 1.8V. 1NL1. 11.0. DD = … |
File Format / Size | PDF / 313 Kb |
ADCMP671. Data Sheet. 12.0. 11.5. 1NH1. VDD = 1.8V. 1NL1. 11.0. DD = 2.5V. INH2. 10.5. DD = 3.3V. INL2. 10.0. DD = 5.0V. 9.5. 9.0. 8.5. FOUR TYPICAL PARTS
ADCMP671 Data Sheet 12.0 12.0 11.5 1NH1 11.5 VDD = 1.8V 1NL1 V 11.0 11.0 DD = 2.5V INH2 V 10.5 10.5 DD = 3.3V INL2 V 10.0 10.0 DD = 5.0V 9.5 9.5 V) V) m 9.0 9.0 ( (m S 8.5 FOUR TYPICAL PARTS IS 8.5 ESI 8.0 VDD = 5V ES 8.0 ER 7.5 ER T 7.5 7.0 ST YS 7.0 Y H 6.5 H 6.5 6.0 6.0 5.5 5.5 5.0 5.0 4.5 4.5 4.0 4.0
3
–40 –20 0 20 40 60 80 100 120
0 01
01 0- 0-
TEMPERATURE (°C)
16
TEMPERATURE (°C)
16 10 10 Figure 10. Hysteresis vs. Temperature for Four Typical Parts Figure 13. Hysteresis vs. Temperature for Various VDD Voltages
12 1 TA = +125°C 11 0 10 ) V T m TA = –40°C V) A = +25°C ( –1 m 9 T TA = +25°C ( IF S TA = +85°C TA = +85°C SH T ESI 8 D A = +125°C –2 L ER T O 7 YS H T ESH A = –40°C R –3 H 6 T –4 5 4 –5
4
1.7 2.2 2.7 3.2 3.7 4.2 4.7 5.2 5.7
1 1 0
1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 2.3 2.4 2.5
01 0- 0-
SUPPLY VOLTAGE (V)
16
SUPPLY VOLTAGE (V)
16 10 10 Figure 11. Hysteresis vs. Supply Voltage Figure 14. Minimum Supply Voltage
10 50 NO LOAD CURRENT 9 40 A) A) µ µ ( 8 ( NT TA = +125°C T NT 30 A = +85°C 7 CURRE CURRE Y Y L T L 20 P A = +25°C P 6 UP UP S S T T A = –40°C A = +25°C 10 5 TA = +85°C TA = +125°C TA = –40°C 4 0
2 5
01
0 0.5 1.0 1.5
01 0- 0-
SUPPLY VOLTAGE (V)
16
SUPPLY VOLTAGE (V)
16 10 10 Figure 12. Quiescent Supply Current vs. Supply Voltage Figure 15. Start-Up Supply Current Rev. 0 | Page 10 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION COMPARATORS AND INTERNAL REFERENCE POWER SUPPLY INPUTS HYSTERESIS VOLTAGE MONITORING SCHEME OUTPUTS OUTLINE DIMENSIONS ORDERING GUIDE
