Datasheet ADCMP609 (Analog Devices) - 6
Description | Rail-to-Rail, Fast, Low Power 2.5 V to 5.5 V, Single-Supply TTL/CMOS Comparator |
Pages / Page | 12 / 6 — ADCMP609. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 400. 160. 150. … |
Revision | C |
File Format / Size | PDF / 265 Kb |
ADCMP609. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 400. 160. 150. 300. 140. 130. 200. 120. VCC = 2.5V. VCC = 5.5V. ) 110. 100. m 100. ( T. R E
ADCMP609 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS
VCC = 2.5 V, TA = 25°C, unless otherwise noted.
400 160 150 300 140 130 200 120 VCC = 2.5V VCC = 5.5V ) 110 ) V A 100 m 100 µ ( ( T IS 90 N S 0 E E 80 R R E 70 T CUR –100 S 60 Y H 50 VCC = 2.5 –200 40 30 –300 20 VCC = 5.5
003 006
10
06918-
–400
06918-
0 –1 0 1 2 3 4 5 6 7 0 100 200 300 400 500 600 700 800 900 1000 1100 1200 1300 HYS PIN VOLTAGE (V) HYS RESISTOR (kΩ)
Figure 3. HYS Pin Current (μA) vs. Voltage (V) Figure 6. Hysteresis vs. HYS Resistor
5 1.5 4 SOURCE 3 1.0 SINK 2 ) A (m 1 T 0.5 N A) E µ 0 R ( I B CUR –1 0 AD –2 O L +125°C –3 –0.5 +25°C –4
004 007
–40°C
06918-
–5
06918-
–1.0 –1.0 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 –1.0 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 VCM AT VCC (2.5V) VOUT (V)
Figure 4. Input Bias Current vs. Input Common-Mode Voltage (V) Figure 7. Load Current vs. VOH/VOL
60 38.0 37.8 55 37.6 PROPAGATION DELAY FALL ) 50 s (n ) 37.4 s Y (n A 45 L Y E 37.2 D LA VCC = 5.5V E N 40 RISE DELAY 37.0 D IO T PROPAGATION DELAY RISE A 36.8 G TION 35 VCC = 5.5V A P GA FALL DELAY O 36.6 A 30 R V P OP CC = 2.5V R FALL DELAY 36.4 P 25 VCC = 2.5V 36.2 RISE DELAY
008
20
06918-
36.0 0 50 100 150
005
0.5 1.0 1.5 2.0 2.5 3.0 OD (mV)
06918-
VCM AT VCC (2.5V)
Figure 5. Propagation Delay vs. Input Overdrive at VCC = 2.5 V and 5.5 V Figure 8. Propagation Delay vs. Input Common-Mode Voltage (V) Rev. C | Page 6 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING TTL-/CMOS-COMPATIBLE OUTPUT STAGE OPTIMIZING PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS CROSSOVER BIAS POINT MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATIONS CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
