Datasheet ADCMP609 (Analog Devices) - 7
Description | Rail-to-Rail, Fast, Low Power 2.5 V to 5.5 V, Single-Supply TTL/CMOS Comparator |
Pages / Page | 12 / 7 — Data Sheet. ADCMP609. 0.5V/DIV. 100ns/DIV. 1V/DIV |
Revision | C |
File Format / Size | PDF / 265 Kb |
Data Sheet ADCMP609 Q Q Q Q
009 010
0.5V/DIV 100ns/DIV 1V/DIV 100ns/DIV
06918- 06918- Figure 9. 1 MHz Output Voltage Waveform at VCC = 2.5 V Figure 10. 1 MHz Output Voltage Waveform at VCC = 5.5 V Rev. C | Page 7 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING TTL-/CMOS-COMPATIBLE OUTPUT STAGE OPTIMIZING PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS CROSSOVER BIAS POINT MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATIONS CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
