Datasheet ADCMP603 (Analog Devices) - 4
Description | Rail-to-Rail, Very Fast, 2.5 V to 5.5 V, Single-Supply TTL/CMOS Comparator |
Pages / Page | 16 / 4 — ADCMP603. Data Sheet. Parameter. Symbol. Test Conditions/Comments Min. … |
Revision | A |
File Format / Size | PDF / 321 Kb |
ADCMP603. Data Sheet. Parameter. Symbol. Test Conditions/Comments Min. Typ. Max. Unit
ADCMP603 Data Sheet Parameter Symbol Test Conditions/Comments Min Typ Max Unit
AC PERFORMANCE1 Rise Time /Fall time tR/tF 10% to 90%, VCCO = 2.5 V 2.2 ns 10% to 90%, VCCO = 5.5 V 4.5 ns Propagation Delay tPD VOD = 50 mV, VCCO = 2.5 V 3.5 ns VOD = 50 mV, VCCO = 5.5 V 4.8 ns VOD = 10 mV, VCCO = 2.5 V 5 ns Propagation Delay Skew—Rising to tPINSKEW VCCO = 2.5 V to 5.5 V 500 ps Falling Transition VOD = 50 mV Propagation Delay Skew—Q to QB tDIFFSKEW VCCO =2.5 V to 5.5 V 300 ps VOD = 50 mV Overdrive Dispersion 10 mV < VOD < 125 mV 1.5 ns Common-Mode Dispersion −2 V < VCM < VCCI + 2 V 200 ps VOD = 50 mV Minimum Pulse Width PWMIN VCCI = VCCO = 2.5 V 3.3 ns PWOUT = 90% of PWIN VCCI = VCCO = 5.5 V 5.5 ns PWOUT = 90% of PWIN POWER SUPPLY Input Supply Voltage Range VCCI 2.5 5.5 V Output Supply Voltage Range VCCO 2.5 5.5 V Positive Supply Differential VCCI − VCCO Operating −3.0 +3.0 V Positive Supply Differential VCCI − VCCO Nonoperating −5.5 +5.5 V Input Section Supply Current IVCCI VCCI = 2.5 V to 5.5 V 1.1 1.8 mA Output Section Supply Current IVCCO VCCI = 2.5 V to 5.5 V 2.3 3.5 mA Power Dissipation PD VCC = 2.5 V 9 11 mW PD VCC = 5.5 V 21 30 mW Power Supply Rejection Ratio PSRR VCCI = 2.5 V to 5.5 V −50 dB Shutdown Mode Supply Current VCC =2.5 V 290 430 µA 1 VIN = 100 mV square input at 50 MHz, VCM = 0 V, CL = 5 pF, VCCI = VCCO = 2.5 V, unless otherwise noted. Rev. A | Page 4 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS TIMING INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING TTL-/CMOS-COMPATIBLE OUTPUT STAGE USING/DISABLING THE LATCH FEATURE OPTIMIZING PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS CROSSOVER BIAS POINT MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
