Datasheet ADCMP350, ADCMP354, ADCMP356 (Analog Devices) - 5
DescriptionComparators and Reference Circuits
Pages / Page10 / 5 — Data Sheet. ADCMP350/ADCMP354/ADCMP356. PIN CONFIGURATION AND FUNCTION …
RevisionE
File Format / SizePDF / 216 Kb
Data Sheet. ADCMP350/ADCMP354/ADCMP356. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VCC. ADCMP350/ ADCMP354/ ADCMP356. GND. OUT
Data Sheet ADCMP350/ADCMP354/ADCMP356 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VCC ADCMP350/ ADCMP354/ ADCMP356 GND OUT
Data Sheet ADCMP350/ADCMP354/ADCMP356 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS V 4 IN 1 VCC ADCMP350/ ADCMP354/ ADCMP356
2 0 -0
GND 2 3 OUT
2 1 1 5 0 Figure 3. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 VIN Monitors Analog Input Voltage. Connected to inverting or noninverting input depending on the model number. 2 GND Ground. 3 OUT Digital Output. Open-drain or push-pull options depending on the model number. 4 VCC Power Supply. Rev. E | Page 5 of 10 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION ADDING HYSTERESIS VOLTAGE DETECTOR OUTLINE DIMENSIONS ORDERING GUIDE
