Datasheet ADCMP350, ADCMP354, ADCMP356 (Analog Devices) - 4
DescriptionComparators and Reference Circuits
Pages / Page10 / 4 — ADCMP350/ADCMP354/ADCMP356. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table …
RevisionE
File Format / SizePDF / 216 Kb
ADCMP350/ADCMP354/ADCMP356. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Rating. ESD CAUTION
ADCMP350/ADCMP354/ADCMP356 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
TA = 25°C, unless otherwise noted. Stresses at or above those listed under Absolute Maximum
Table 3.
Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational VCC −0.3 V to +6 V section of this specification is not implied. Operation beyond VIN −0.3 V to +25 V the maximum operating conditions for extended periods may OUT (Open-Drain) −0.3 V to +25 V affect product reliability. OUT (Push-Pull) −0.3 V to (VCC + 0.3 V) Operating Temperature Range −40°C to +125°C
ESD CAUTION
Storage Temperature Range −65°C to +150°C θJA Thermal Impedance 146°C/W Lead Temperature Soldering (10 sec) 300°C Vapor Phase (60 sec) 215°C Infrared (15 sec) 220°C Rev. E | Page 4 of 10 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION ADDING HYSTERESIS VOLTAGE DETECTOR OUTLINE DIMENSIONS ORDERING GUIDE
