Datasheet ADCMP350, ADCMP354, ADCMP356 (Analog Devices) - 3
DescriptionComparators and Reference Circuits
Pages / Page10 / 3 — Data Sheet. ADCMP350/ADCMP354/ADCMP356. SPECIFICATIONS. Table 2. …
RevisionE
File Format / SizePDF / 216 Kb
Data Sheet. ADCMP350/ADCMP354/ADCMP356. SPECIFICATIONS. Table 2. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments
Data Sheet ADCMP350/ADCMP354/ADCMP356 SPECIFICATIONS Table 2 Parameter Min Typ Max Unit Test Conditions/Comments
VCC = full operating range, TA = −40°C to +125°C, unless otherwise noted.
Table 2. Parameter Min Typ Max Unit Test Conditions/Comments
SUPPLY Operating Voltage Range VCC 2.25 5.5 V VIN 0 22 V Supply Current 10 15 µA VIN THRESHOLD VCC = 3.3 V Rising 0.579 0.6 0.621 V TA = −40°C to +85°C 0.579 0.6 0.624 V TA = −40°C to +125°C Falling 0.564 0.585 0.606 V TA = −40°C to +85°C 0.564 0.585 0.609 V TA = −40°C to +125°C INPUT BIAS CURRENT 10 nA VIN = 0.6 V 170 µA VIN = 22 V THRESHOLD TEMPERATURE COEFFICIENT 30 ppm/°C VIN TO OUT DELAY 5 µs VIN = VTH to (VTH − 100 mV) OUT VOLTAGE Low 0.4 V VIN < VTH minimum, ISINK = 1.2 mA High 0.8 × VCC V VIN > VTH maximum, ISOURCE = 500 µA, push-pull only OUTPUT TIME COUT = 15 pF Rise 30 ns Fall 45 ns OUTPUT LEAKAGE CURRENT 1 µA OUT = 22 V, open-drain only Rev. E | Page 3 of 10 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION ADDING HYSTERESIS VOLTAGE DETECTOR OUTLINE DIMENSIONS ORDERING GUIDE
