Datasheet CMP04 (Analog Devices)
Description | Quad Low Power, Precision Comparator |
Pages / Page | 8 / 1 — Quad Low Power,. Precision Comparator. CMP04. FEATURES. PIN CONNECTIONS. … |
Revision | E |
File Format / Size | PDF / 219 Kb |
Quad Low Power,. Precision Comparator. CMP04. FEATURES. PIN CONNECTIONS. High Gain: 200 V/mV Typ Single- or Dual-Supply Operation
a
Quad Low Power, Precision Comparator CMP04 FEATURES PIN CONNECTIONS High Gain: 200 V/mV Typ Single- or Dual-Supply Operation 14-Lead SOIC Input Voltage Range Includes Ground Low Power Consumption (1.5 mW/Comparator) Low Input Bias Current: 100 nA Max OUT 2 1 14 OUT 3 Low Input Offset Current: 10 nA Max OUT 1 2 13 Low Offset Voltage: 1 mV Max OUT 4 1 4 Low Output Saturation Voltage: 250 mV @ 4 mA V+ 3 12 GND Logic Output Compatible with TTL, DTL, ECL, MOS, IN 1– 4 11 IN 4+ and CMOS IN 1+ 5 10 IN 4– Directly Replaces LM139/LM239/LM339 Comparators IN 2– 6 2 3 9 IN 3+ IN 2+ 7 8 IN 3– CMP04 GENERAL DESCRIPTION TYPICAL INTERFACE
Four precision independent comparators comprise the CMP04. Performance highlights include a very low offset voltage, low
5.0
output saturation voltage, and high gain in a single-supply design. The input voltage range includes ground for single-
1/4 3 100k
CD4011
supply operation and V– for split supplies. A low power
1/4
supply current of 2 mA, which is independent of supply voltage,
CMP04
makes this the preferred comparator for precision applications
12
requiring minimal power consumption. Maximum logic inter- face flexibility is offered by the open-collector TTL output. Figure 2a. Driving CMOS
5.0 V+ 3 3.5
A 100
A 3.5
A 100
A 10k
OUTPUT 1/4 CMP04 Q8 1/4 SN7400 Q2 Q3 12 +INPUT Q1 Q4 –INPUT * * Q7
Figure 2b. Driving TTL
Q5 Q6 *SUBSTRATE DIODES
Figure 1. Simplified Schematic (1/4 CMP04)
Rev. E Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES GENERAL DESCRIPTION PIN CONNECTIONS TYPICAL INTERFACE SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ELECTRICAL CHARACTERISTICS Typical Performance Characteristics TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE Revision History
