Datasheet AD8469 (Analog Devices) - 7
Description | Fast, Rail-to-Rail, Low Power, 2.5 V to 5.5 V, Single-Supply TTL/CMOS Comparator |
Pages / Page | 12 / 7 — Data Sheet. AD8469. 0.5V/DIV. 10ns/DIV. 1V/DIV |
File Format / Size | PDF / 264 Kb |
Data Sheet AD8469 Q Q Q Q
009 010
0.5V/DIV 10ns/DIV 1V/DIV 10ns/DIV
10490- 10490- Figure 9. 1 MHz Output Voltage Waveform, VCC = 2.5 V Figure 10. 1 MHz Output Voltage Waveform, VCC = 5.5 V Rev. 0 | Page 7 of 12 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Power/Ground Layout and Bypassing TTL-/CMOS-Compatible Output Stage Optimizing Performance Comparator Propagation Delay Dispersion Comparator Hysteresis Crossover Bias Point Minimum Input Slew Rate Requirement Typical Applications Circuits Outline Dimensions Ordering Guide Automotive Products
