Datasheet AD8469 (Analog Devices) - 6 Manufacturer Analog Devices Description Fast, Rail-to-Rail, Low Power, 2.5 V to 5.5 V, Single-Supply TTL/CMOS Comparator Pages / Page 12 / 6 — AD8469. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 400. 160. 150. … File Format / Size PDF / 264 Kb Document Language English
AD8469. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 400. 160. 150. 300. 140. 130. 200. 120. A (µ. VCC = 2.5V. VCC = 5.5V. ) 110. 100. E R. R E. IN CUR
Model Line for this Datasheet Text Version of Document AD8469 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS VCC = 2.5 V, TA = 25°C, unless otherwise noted.400 160 150 300 140 130 200 ) 120 A (µ VCC = 2.5V VCC = 5.5V ) 110 V T 100 N 100 (m E R IS 90 S 0 E 80 R E 70 IN CUR T –100 P S 60 S Y H 50 HY VCC = 2.5V –200 40 30 –300 20 VCC = 5.5V 10 –400 0 –1 0 1 2 3 4 5 6 7 0030 100 200 300 400 500 600 700 800 900 1000 1100 1200 1300 006HYS PIN VOLTAGE (V) 10490-HYS RESISTOR (kΩ) 10490- Figure 3. HYS Pin Current vs. Voltage, VCC = 2.5 V and 5.5 V Figure 6. Hysteresis vs. HYS Resistor, VCC = 2.5 V and 5.5 V5 1.5 VCC = 2.5V 4 SOURCE 3 1.0 SINK 2 ) A) A µ ( (m 1 T 0.5 NT N E 0 R CURRE CUR –1 0 AS AD BI –2 O L +125°C –3 –0.5 +25°C –4 –40°C –5 –1.0 –1.0 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 004–1.0 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 007COMMON-MODE VOLTAGE (V) OUTPUT VOLTAGE (V) 10490- 10490- Figure 4. Input Bias Current vs. Input Common-Mode Voltage, VCC = 2.5 V Figure 7. Load Current vs. Output Voltage60 38.0 37.8 55 FALL DELAY ) 37.6 ) s 50 s (n (n Y 37.4 Y A LA 45 L E E 37.2 D V D CC = 5.5V N 40 RISE DELAY 37.0 IO TION T RISE DELAY A GA 36.8 35 G A VCC = 5.5V A FALL DELAY P OP O 36.6 R R 30 P VCC = 2.5V P FALL DELAY 36.4 25 VCC = 2.5V 36.2 RISE DELAY VCC = 2.5V 20 36.0 0 50 100 150 0050.5 1.0 1.5 2.0 2.5 3.0 008OVERDRIVE (mV) 10490-COMMON-MODE VOLTAGE (V) 10490- Figure 5. Propagation Delay vs. Input Overdrive, VCC = 2.5 V and 5.5 V Figure 8. Propagation Delay vs. Input Common-Mode Voltage, VCC = 2.5 V Rev. 0 | Page 6 of 12 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Power/Ground Layout and Bypassing TTL-/CMOS-Compatible Output Stage Optimizing Performance Comparator Propagation Delay Dispersion Comparator Hysteresis Crossover Bias Point Minimum Input Slew Rate Requirement Typical Applications Circuits Outline Dimensions Ordering Guide Automotive Products
