Datasheet HMC675LC3C (Analog Devices) - 3
Description10 GHz Latched Comparator with RSCML Output Stage
Pages / Page10 / 3 — HMC675LC3C. 10 GHz LATCHED COMPARATOR. WITH RSCML OUTPUT STAGE. …
File Format / SizePDF / 569 Kb
HMC675LC3C. 10 GHz LATCHED COMPARATOR. WITH RSCML OUTPUT STAGE. Dispersion vs. Overdrive Voltage
HMC675LC3C 10 GHz LATCHED COMPARATOR WITH RSCML OUTPUT STAGE Dispersion vs Overdrive Voltage
HMC675LC3C
v10.0514
10 GHz LATCHED COMPARATOR WITH RSCML OUTPUT STAGE Dispersion vs. Overdrive Voltage Propagation Delay vs. Common Mode[1]
11 15 T 12.5 9 M 10 7 7.5 5 tPD 5 S - S 2.5 3 DISPERSION (ps) R 0 1 O -2.5 -1 -5 AT 0 10 20 30 40 50 60 70 80 90 100 -2 -1.5 -1 -0.5 0 0.5 1 1.5 2 R OVERDRIVE VOLTAGE (mV) COMMON MODE VOLTAGE (mV) A Rising Edge Rising Edge Falling Edge Falling Edge P
Comparator Hysteresis
OM
Output Voltage vs. Temperature vs. Rhys Control Resistor
C 0.1 15 0 -0.1 ) V 10 m -0.2 -0.3 VOLTAGE (V) 5 HYSTERESIS ( -0.4 -0.5 -0.6 0 -45 -32 -19 -6 7 20 33 46 59 72 85 100 1000 10000 TEMPERATURE (C) RESISTANCE (Ohm) VOH VOL
Eye Diagram
[1] Vcci = 3.3 V, Vcc0 = 0, Vee = -3 V, VTERM = 0 I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
