HMC675LC3C v10.0514 10 GHz LATCHED COMPARATORWITH RSCML OUTPUT STAGEAbsolute Maximum Ratings Input Supply Voltage (Vcci to GND) -0.5 V to +4 V Output Supply Voltage (Vcco to GND) -0.5 V to +4 V ELECTROSTATIC SENSITIVE DEVICE Positive Supply Voltage Differential OBSERVE HANDLING PRECAUTIONS T -0.5 V to +3.3 V (Vcci - Vcco) M Input Voltage -2 V to +2 V Differential Input Voltage -2 V to +2 V Input Voltage, Latch Enable -0.5 V to Vcci +0.5 V S - S Applied Voltage (HYS) Vee to GND R Maximum Input Current ±20 mA O Output Current 20 mA Junction Temperature 125 °C AT Continuous Pdiss (T = 85 °C) 0.816 W R (Derate 20.4 mW/°C above 85 °C) A Thermal Resistance (Rth) (Junction to Lead) 49 °C/W P Storage Temperature -65 °C to +150 °C Operating Temperature -40 °C to +85 °C ESD Sensitivity (HBM) Class 1A OM C Outline Drawing NOTES: 1. PACKAGE BODY MATERIAL: ALUMINA 2. LEAD AND GROUND PADDLE PLATING: 30-80 MICROINCHES GOLD OVER 50 MICROINCHES MINIMUM NICKEL. 3. DIMENSIONS ARE IN INCHES [MILLIMETERS]. 4. LEAD SPACING TOLERANCE IS NON-CUMULATIVE. 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm DATUM -C- 6. ALL GROUND LEADS MUST BE SOLDERED TO PCB RF GROUND. 7. PADDLE MUST BE SOLDERED TO Vee. Package Information Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC675LC3C Alumina, White Gold over Nickel MSL3 [1] H675 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com 6 Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
