Datasheet HMC674LC3C, HMC674LP3E (Analog Devices) - 9
Description9.3 GHz Latched Comparator with RSPECL Output Stage
Pages / Page14 / 9 — Data Sheet. HMC674LC3C/HMC674LP3E. TYPICAL PERFORMANCE CHARACTERISTICS. …
RevisionK
File Format / SizePDF / 331 Kb
Data Sheet. HMC674LC3C/HMC674LP3E. TYPICAL PERFORMANCE CHARACTERISTICS. 15.0. RISING EDGE. FALLING EDGE. 12.5. 10.0. 7.5. (p N. t PD. 5.0
Data Sheet HMC674LC3C/HMC674LP3E TYPICAL PERFORMANCE CHARACTERISTICS 15.0 RISING EDGE FALLING EDGE 12.5 10.0 7.5 (p N t PD 5.0
Data Sheet HMC674LC3C/HMC674LP3E TYPICAL PERFORMANCE CHARACTERISTICS 11 15.0 RISING EDGE RISING EDGE FALLING EDGE FALLING EDGE 12.5 9 10.0 s) ) 7 p s ( 7.5 (p N t PD O D SI 5 5.0 LIZE A ISPER M 2.5 D 3 OR N 0 1 –2.5 –1 –5.0
1 1
0 10 20 30 40 50 60 70 80 90 100
009
–2.0 –1.5 –1.0 –0.5 0 0.5 1.0 1.5 2.0
0
OVERDRIVE VOLTAGE (mV)
14861-
COMMON-MODE VOLTAGE (V)
14861- Figure 9. Dispersion vs. Overdrive Voltage Figure 11. Normalized Propagation Delay (tPD) vs. Common-Mode Voltage
2.8 15 VOH VOL 2.6 ) V ( 10 V) GE 2.4 S (m OLTA ESI T V ER U 2.2 TP YST H 5 OU 2.0 1.8 0 –45 –32 –19 –6 7 20 33 46 59 72 85
010
100 1k 10k
012
TEMPERATURE (°C) RESISTANCE (Ω)
14861- 14861- Figure 10. Output Voltage vs. Temperature Figure 12. Comparator Hysteresis vs. RHYS Control Resistance Rev. K | Page 9 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS LATCH ENABLE (LE/) SPECIFICATIONS DC OUTPUT SPECIFICATIONS AC SPECIFICATIONS POWER SUPPLY SPECIFICATIONS TIMING DESCRIPTIONS Timing Diagram ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION POWER SEQUENCING APPLICATIONS INFORMATION EVALUATION PRINTED CIRCUIT BOARD (PCB) APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
