Datasheet ADCMP565 (Analog Devices) - 3
Description | Dual Ultrafast Voltage Comparator |
Pages / Page | 16 / 3 |
File Format / Size | PDF / 207 Kb |
ADCMP565 SPECIFICATIONS
Table 1. ADCMP565 ELECTRICAL CHARACTERISTICS (VCC = +5.0 V, VEE = −5.2 V, TA = 25°C, unless otherwise noted.) Parameter Symbol Condition Min Typ Max Unit
DC INPUT CHARACTERISTICS (See Note) Input Common-Mode Range VCM −2.0 +3.0 V Input Differential Voltage −5 +5 V Input Offset Voltage VOS −6.0 ±1.5 +6.0 mV Input Offset Voltage Channel Matching −8 +1 +8 mV Offset Voltage Tempco DVOS/dT 5.0 µV/°C Input Bias Current IBC −10.0 +24 +40.0 µA Input Bias Current Tempco 17 nA/°C Input Offset Current −5.0 ±0.5 +5.0 µA Input Capacitance CIN 1.75 pF Input Resistance, Differential Mode 100 kΩ Input Resistance, Common Mode 600 kΩ Open Loop Gain 60 dB Common-Mode Rejection Ratio CMRR VCM = −2.0 V to +3.0 V 69 dB Hysteresis ±1.0 mV LATCH ENABLE CHARACTERISTICS Latch Enable Common-Mode Range VLCM −2.0 0 V Latch Enable Differential Input Voltage VLD 0.4 2.0 V Input High Current @ 0.0 V −10 +6 +10 µA Input Low Current @ −2.0 V −10 +6 +10 µA Latch Setup Time tS 250 mV overdrive 50 ps Latch to Output Delay tPLOH, tPLOL 250 mV overdrive 280 ps Latch Pulse Width tPL 250 mV overdrive 150 ps Latch Hold Time tH 250 mV overdrive 10 ps OUTPUT CHARACTERISTICS Output Voltage—High Level VOH ECL 50 Ω to −2.0 V −1.08 −0.81 V Output Voltage—Low Level VOL ECL 50 Ω to −2.0 V −1.95 −1.61 V Rise Time tR 20% to 80% 160 ps Fall Time tF 20% to 80% 145 ps AC PERFORMANCE Propagation Delay tPD 1 V overdrive 310 ps Propagation Delay tPD 20 mV overdrive 375 ps Propagation Delay Tempco 0.5 ps/°C Prop Delay Skew—Rising Transition to ±10 ps Falling Transition Within Device Propagation Delay Skew— ±10 ps Channel to Channel Propagation Delay Dispersion vs. 1 MHz, 1 ns tR, tF ±10 ps Duty Cycle Propagation Delay Dispersion vs. Overdrive 50 mV to 1.5 V 50 ps Propagation Delay Dispersion vs. Overdrive 20 mV to 1.5 V 50 ps Propagation Delay Dispersion vs. 0 V to 1 V swing, 50 ps Slew Rate 20% to 80%, 50 ps and 600 ps tR, tF Propagation Delay Dispersion vs. 1 V swing, 5 ps Common-Mode Voltage −1.5 V to 2.5 VCM Equivalent Input Rise Time Bandwidth BW 0 V to 1 V swing, 5000 MHz 20% to 80%, 50 ps tR, tF Rev. 0 | Page 3 of 16 Document Outline SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TIMING INFORMATION APPLICATION INFORMATION CLOCK TIMING RECOVERY OPTIMIZING HIGH SPEED PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
