Datasheet AD8611, AD8612 (Analog Devices) - 5
DescriptionUltrafast, 4 ns Single-Supply Comparators
Pages / Page20 / 5 — Data Sheet. AD8611/AD8612. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. …
File Format / SizePDF / 317 Kb
Data Sheet. AD8611/AD8612. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Rating. THERMAL RESISTANCE. Table 4. Package Type. θ 1. Unit
Data Sheet AD8611/AD8612 ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating THERMAL RESISTANCE Table 4 Package Type θ 1 Unit
Stresses at or above those listed under Absolute Maximum
Table 3.
Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these Total Analog Supply Voltage 7.0 V or any other conditions above those indicated in the operational Digital Supply Voltage 7.0 V section of this specification is not implied. Operation beyond Input Voltage VCC +0.3 V to the maximum operating conditions for extended periods may VEE −0.3 V affect product reliability. Differential Input Voltage ±5 V Output Short-Circuit Duration to GND Indefinite
THERMAL RESISTANCE
Input Current ±5 mA
Table 4.
Storage Temperature Range
Package Type θ 1 θ
R, RU, RM Packages −65°C to +150°C
JA JC Unit
8-Lead SOIC (R) 158 43 °C/W Operating Temperature Range −40°C to +85°C 8-Lead MSOP (RM) 240 43 °C/W Junction Temperature Range 14-Lead TSSOP (RU) 240 43 °C/W R, RU, RM Packages −65°C to +150°C Lead Temperature Range (Soldering, 10 sec) 300°C 1θJA is specified for the worst-case conditions, that is, a device in socket for P-DIP and a device soldered in circuit board for SOIC and TSSOP.
ESD CAUTION
Rev. B | Page 5 of 20 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION OPTIMIZING HIGH SPEED PERFORMANCE UPGRADING THE LT1394 AND LT1016 MAXIMUM INPUT FREQUENCY AND OVERDRIVE OUTPUT LOADING CONSIDERATIONS USING THE LATCHTO MAINTAIN A CONSTANT OUTPUT INPUT STAGE AND BIAS CURRENTS USING HYSTERESIS CLOCK TIMING RECOVERY A 5 V, HIGH SPEED WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
