Datasheet AD790 (Analog Devices) - 2
DescriptionFast, Precision Comparator
Pages / Page10 / 2 — AD790–SPECIFICATIONS DUAL SUPPLY (Operation @ 25. C and +VS = 15 V, –VS = …
RevisionE
File Format / SizePDF / 318 Kb
AD790–SPECIFICATIONS DUAL SUPPLY (Operation @ 25. C and +VS = 15 V, –VS = –15 V, VLOGIC = 5 V unless otherwise noted.)
AD790–SPECIFICATIONS DUAL SUPPLY (Operation @ 25 C and +VS = 15 V, –VS = –15 V, VLOGIC = 5 V unless otherwise noted.)
C and +VS = 15 V, –VS = –15 V, VLOGIC = 5 V unless otherwise noted.) AD790J/A AD790K/B AD790S Parameter Conditions Min Typ Max Min Typ Max Min Typ Max Unit
RESPONSE CHARACTERISTIC 100 mV Step Propagation Delay, tPD 5 mV Overdrive 40 45 40 45 40 45 ns TMIN to TMAX 45/50 45/50 60 ns OUTPUT CHARACTERISTICS Output HIGH Voltage, VOH 1.6 mA Source 4.65 4.65 4.65 6.4 mA Source
4.3
4.45
4.3
4.45
4.3
4.45 V TMIN to TMAX 4.3/
4.3 4.3 4.3
V Output LOW Voltage, VOL 1.6 mA Sink 0.35 0.35 0.35 V 6.4 mA Sink 0.44
0.5
0.44
0.5
0.44
0.5
V TMIN to TMAX 0.5/
0.5 0.5 0.5
V INPUT CHARACTERISTICS Offset Voltage1 0.2
1.0
0.05
0.25
0.2
1.0
mV TMIN to TMAX 1.5
0.5 1.5
mV Hysteresis2 TMIN to TMAX 0.3 0.4 0.6
0.3
0.4
0.5 0.3
0.4
0.65
mV Bias Current Either Input 2.5 5 1.8
3.5
2.5
5
µA TMIN to TMAX 6.5
4.5 7
µA Offset Current 0.04
0.25
0.02
0.15
0.04
0.25
µA TMIN to TMAX 0.3
0.2 0.4
µA Power Supply Rejection Ratio DC VS ± 20%
80
90
88
100
80
90 dB TMIN to TMAX 76 88
85
93
76
85 dB Input Voltage Range Differential Voltage V ⴞ ⴞ S ≤± 15 V ⴞ
VS VS VS
V Common Mode –VS +VS–2 V –VS +VS–2 V –VS +VS–2 V V Common Mode Rejection Ratio –10 V<VCM
80
95
88
105
80
95 dB <+10 V TMIN to TMAX 76 90
85
100
76
88 dB Input Impedance 20储2 20储2 20储2 MΩ储pF LATCH CHARACTERISTICS Latch Hold Time, tH 25 35 25 35 25 35 ns Latch Setup Time, tS 5 10 5 10 5 10 ns LOW Input Level, VIL TMIN to TMAX 0.8
0.8 0.8
V HIGH Input Level, VIH TMIN to TMA X 1.6
1.6 1.6
V Latch Input Current 2.3 5 2.3
3.5
2.3
5
µA TMIN to TMAX 7
5 8
µA SUPPLY CHARACTERISTICS Diff Supply Voltage3 VLOGIC = 5 V TMIN to TMAX 4.5 33
4.5 33 4.7 33
V Logic Supply TMIN to TMAX 4.0 7
4.0 7 4.2 7
V Quiescent Current +VS +VS = 15 V 8
10
8
10
8
10
mA –VS –VS = –15 V 4
5
4
5
4
5
mA VLOGIC VLOGIC = 5 V 2
3.3
2
3.3
2
3.3
mA Power Dissipation
242 242 242
mW TEMPERATURE RANGE Rated Performance TMIN to TMAX 0 to 70/–40 to +85 0 to 70/–40 to +85 –55 to +125 °C NOTES 1Defined as the average of the input voltages at the low to high and high to low transition points. Refer to Figure 6. 2Defined as half the magnitude between the input voltages at the low to high and high to low transition points. Refer to Figure 6. 3+VS must be no lower than (VLOGIC –0.5 V) in any supply operating conditions, except during power up. All min and max specifications are guaranteed. Specifications shown in
boldface
are tested on all production units at final test. Specifications subject to change without notice. –2– REV. E
