Datasheet RH137 (Analog Devices) - 4
DescriptionNegative Adjustable Regulator
Pages / Page4 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS. Reference Voltage. Current Limit. …
RevisionD
File Format / SizePDF / 635 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Reference Voltage. Current Limit. Adjust Current. Minimum Load Current. Dropout Voltage
TYPICAL PERFORMANCE CHARACTERISTICS Reference Voltage Current Limit Adjust Current Minimum Load Current Dropout Voltage
RH137
1.28 3.0 100 3V £ ΩVIN – VOUTΩ £ 30V ΩVIN – VOUTΩ = 30V 1.27 10mA £ IOUT £ IMAX 2.5 90 2.0 ΩVIN – VOUTΩ = 5V A) 1.26 μ 80 1.5 1.25 70 1.0 1.24 CURRENT LIMIT (A) ΩVIN – VOUTΩ= 30V 60 0.5 REFERENCE VOLTAGE (V) ADJUST CURRENT ( 1.23 0 50 1.22 –0.5 40 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH137 G01 RH137 G02 RH137 G03
Minimum Load Current Dropout Voltage Regulation
3.0 3.0 14 ΩVIN – VOUTΩ = 10V (VIN – VOUT) = 10V 2.5 2.5 12 10 2.0 2.0 8 1.5 1.5 6 LOAD 1.0 1.0 REGULATION (mV) DROPOUT VOLTAGE (V) 4 MINIMUM LOAD CURRENT (mA) 0.5 0.5 2 LINE 0 0 0 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH137 G04 RH137 G05 RH137 G06
REVISION HISTORY (Revision history begins at Rev D) REV DATE DESCRIPTION PAGE NUMBER
D 01/19 Obsolete K (T0-3 Metal Can) Package 1 Rev. D 4 01/19 www.analog.com ANALOG DEVICES, INC. 1990-2019 Document Outline Description Burn-In Circuit Absolute Maximum Ratings Package/Order Information Table 1. Electrical Characteristics Table 1A. Electrical Characteristics Table 2. Electrical Test Requirements Total Dose Bias Circuit Typical Application Typical Performance Characteristics
