Datasheet ADP7156 (Analog Devices) - 7
Description1.2 A, Ultralow Noise, High PSRR, Fixed Output, RF Linear Regulator
Pages / Page22 / 7 — Data Sheet. ADP7156. TYPICAL PERFORMANCE CHARACTERISTICS. 1.0. 3.35. …
RevisionB
File Format / SizePDF / 636 Kb
Data Sheet. ADP7156. TYPICAL PERFORMANCE CHARACTERISTICS. 1.0. 3.35. 2.3V. 0.9. 2.5V. 3.34. ILOAD = 0mA. 3.0V. 0.8. 3.33. LOAD = 10mA. 4.0V
Data Sheet ADP7156 TYPICAL PERFORMANCE CHARACTERISTICS 1.0 3.35 2.3V 0.9 2.5V 3.34 ILOAD = 0mA 3.0V 0.8 3.33 LOAD = 10mA 4.0V
VIN = VOUT + 0.5 V or 2.3 V, whichever is greater; VEN = VIN; ILOAD = 10 mA; CIN = COUT = 10 µF; CREG = CREF = CBYP = 1 µF; TA = 25°C unless otherwise noted.
1.0 3.35 2.3V 0.9 2.5V 3.34 ILOAD = 0mA 3.0V I 0.8 3.33 LOAD = 10mA 4.0V ILOAD = 100mA 5.0V 0.7 3.32 ILOAD = 600mA 5.5V ILOAD = 1200mA 0.6 3.31 A) µ ( (V) D 0.5 3.30 UT S OV I IN_ 0.4 3.29 0.3 3.28 0.2 3.27 0.1 3.26 0 3.25 –40 –20 0 20 40 60 80 100 120 140
005
3.8 4.0 4.2 4.4 4.6 4.8 5.0 5.2 5.4 5.6
008
TEMPERATURE (°C) VIN (V)
12937- 12937- Figure 5. Shutdown Current (IIN_SD) vs. Temperature Figure 8. Output Voltage (VOUT) vs. Input Voltage (VIN) at Various Input Voltages (VIN), VOUT = 1.8 V at Various Loads, VOUT = 3.3 V
3.35 14 ILOAD = 0mA 13 3.34 ILOAD = 10mA 12 I 3.33 LOAD = 100mA 11 ILOAD = 600mA 10 3.32 ILOAD = 1200mA 9 3.31 8 (V) mA) 3.30 ( 7 UT O ND V 6 I G 3.29 5 3.28 4 ILOAD = 0mA 3 ILOAD = 10mA 3.27 I 2 LOAD = 100mA I 3.26 LOAD = 600mA 1 ILOAD = 1200mA 3.25 0
009
006
–40 –20 0 20 40 60 80 100 120 140 TEMPERATURE (°C) TEMPERATURE (°C)
12937- 12937- Figure 6. Output Voltage (VOUT) vs. Temperature Figure 9. Ground Current (IGND) vs. Temperature at Various Loads, VOUT = 3.3 V at Various Loads, VOUT = 3.3 V
3.35 14 13 3.34 12 3.33 11 3.32 10 9 3.31 8 (V) mA) 3.30 ( UT 7 O ND V 6 3.29 I G 5 3.28 4 3.27 3 2 3.26 1 3.25 0 0.1m 1m 10m 100m 1 10
007
010
ILOAD (A) I
12937-
LOAD (A)
12937- Figure 7. Output Voltage (VOUT) vs. Load Current (ILOAD), VOUT = 3.3 V Figure 10. Ground Current (IGND) vs. Load Current (ILOAD), VOUT = 3.3 V Rev. B | Page 7 of 22 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION CIRCUIT REVISION HISTORY SPECIFICATIONS INPUT AND OUTPUT CAPACITORS, RECOMMENDED SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL DATA THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION ADIsimPOWER DESIGN TOOL CAPACITOR SELECTION Output Capacitor Input and VREG Capacitor REF Capacitor BYP Capacitor Capacitor Properties UNDERVOLTAGE LOCKOUT (UVLO) PROGRAMMABLE PRECISION ENABLE START-UP TIME REF, BYP, AND VREG PINS CURRENT-LIMIT AND THERMAL SHUTDOWN THERMAL CONSIDERATIONS Thermal Characterization Parameter (ΨJB) PRINTED CIRCUIT BOARD (PCB) LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
