Datasheet LT3065 (Analog Devices) - 6
Description45V VIN, 500mA Low Noise, Linear Regulator with Programmable Current Limit and Power Good
Pages / Page28 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. …
RevisionD
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. Typical Dropout Voltage. Guaranteed Dropout Voltage
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted Typical Dropout Voltage Guaranteed Dropout Voltage
LT3065 Series
LT3065 Series
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. Typical Dropout Voltage Guaranteed Dropout Voltage Dropout Voltage
600 700 600 = TEST POINTS 550 650 550 500 600 500 550 450 450 500 400 TJ = 150°C 450 TJ = 150°C 400 350 I T 350 L = 500mA J = 125°C 400 300 350 300 250 300 250 IL = 100mA IL = 50mA 200 250 TJ = 25°C 200 200 DROPOUT VOLTAGE (mV) 150 TJ = 25°C DROPOUT VOLTAGE (mV) DROPOUT VOLTAGE (mV) 150 150 100 100 100 IL = 10mA 50 50 50 0 0 0 0 50 100 150 200 250 300 350 400 450 500 0 50 100 150 200 250 300 350 400 450 500 –75 –50 –25 0 25 50 75 100 125 150 175 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) TEMPERATURE (°C) 3065 G01 3065 G02 3065 G03
Quiescent Current LT3065-1.2 Output Voltage LT3065-1.5 Output Voltage
130 1.224 1.530 120 VIN = VSHDN = 12V IL = 1mA IL = 1mA V 1.220 1.525 110 OUT = 5V IL = 10µA 1.216 1.520 100 1.212 1.515 90 1.208 1.510 80 1.204 1.505 70 60 1.200 1.500 50 1.196 1.495 40 1.192 1.490 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) QUIESCENT CURRENT (µA) 30 1.188 1.485 20 1.184 1.480 V 10 IN = 12V ALL OTHER PINS = 0V 1.180 1.475 0 1.176 1.470 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3065 G04 3065 G05 3065 G06
LT3065-1.8 Output Voltage LT3065-2.5 Output Voltage LT3065-3.3 Output Voltage
1.836 2.55 3.366 1.830 IL = 1mA IL = 1mA I 2.54 3.355 L = 1mA 1.824 2.53 3.344 1.818 3.333 1.812 2.52 3.322 1.806 2.51 3.311 1.800 2.50 3.300 1.794 2.49 3.289 1.788 3.278 OUTPUT VOLTAGE (V) 2.48 1.782 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 3.267 1.776 2.47 3.256 1.770 2.46 3.245 1.764 2.45 3.234 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3065 G07 3065 G08 3065 G09 Rev.D 6 For more information www.analog.com Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
