Datasheet LT3065 (Analog Devices) - 7
Description | 45V VIN, 500mA Low Noise, Linear Regulator with Programmable Current Limit and Power Good |
Pages / Page | 28 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. … |
Revision | D |
File Format / Size | PDF / 1.7 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. LT3065-5 Output Voltage. ADJ Pin Voltage
LT3065 Series
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. LT3065-5 Output Voltage ADJ Pin Voltage LT3065-1.2 Quiescent Current
5.10 612 200 I I L = 1mA T 610 L = 1mA J = 25°C 5.08 175 RL = 240k 608 V 5.06 OUT = 1.2V 606 150 5.04 604 5.02 125 602 5.00 600 100 598 4.98 VSHDN = VIN 75 596 OUTPUT VOLTAGE (V) 4.96 ADJ PIN VOLTAGE (mV) 594 50 4.94 QUIESCENT CURRENT (µA) 592 4.92 25 590 VSHDN = 0V 4.90 588 0 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 0 1 2 3 4 5 6 7 8 9 10 11 TEMPERATURE (°C) TEMPERATURE (°C) INPUT VOLTAGE (V) 3065 G10 3065 G11 3065 G12
LT3065-1.5 Quiescent Current LT3065-1.8 Quiescent Current LT3065-2.5 Quiescent Current
200 200 200 TJ = 25°C TJ = 25°C TJ = 25°C 175 RL = 300k 175 RL = 360k 175 RL = 500k VOUT = 1.5V VOUT = 1.8V VOUT = 2.5V 150 150 150 125 125 125 100 100 100 VSHDN = VIN VSHDN = VIN VSHDN = VIN 75 75 75 QUIESCENT CURRENT (µA) 50 QUIESCENT CURRENT (µA) 50 QUIESCENT CURRENT (µA) 50 25 25 25 VSHDN = 0V VSHDN = 0V VSHDN = 0V 0 0 0 0 1 2 3 4 5 6 7 8 9 10 11 0 1 2 3 4 5 6 7 8 9 10 11 0 1 2 3 4 5 6 7 8 9 10 11 INPUT VOLTAGE (V) INPUT VOLTAGE (V) INPUT VOLTAGE (V) 3065 G13 3065 G14 3065 G15
LT3065-3.3 Quiescent Current LT3065-5 Quiescent Current Quiescent Current
200 200 130 TJ = 25°C TJ = 25°C 120 TJ = 25°C 175 RL = 660k 175 RL = 1M VOUT = 5V VOUT = 3.3V VOUT = 5V 110 IL = 10µA 150 150 100 90 125 125 80 70 100 100 VSHDN = VIN V 60 SHDN = VIN VSHDN = VIN 75 75 50 40 QUIESCENT CURRENT (µA) 50 QUIESCENT CURRENT (µA) 50 QUIESCENT CURRENT (µA) 30 25 25 20 VSHDN = 0V VSHDN = 0V 10 VSHDN = 0V 0 0 0 0 1 2 3 4 5 6 7 8 9 10 11 0 1 2 3 4 5 6 7 8 9 10 11 0 5 10 15 20 25 30 35 40 45 INPUT VOLTAGE (V) INPUT VOLTAGE (V) VIN (V) 3065 G16 3065 G17 3065 G18 Rev.D For more information www.analog.com 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
