Datasheet HMC1060LP3E (Analog Devices) - 4
DescriptionQuad Low Noise High PSRR Linear Voltage Regulator
Pages / Page16 / 4 — HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Figure …
HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Figure 7. VR4 Output Voltage vs
HMC1060LP3E QUAD LOW NOISE HIGH PSRR LINEAR VOLTAGE REGULATOR Figure 7 VR4 Output Voltage vs
HMC1060LP3E
v00.1211
QUAD LOW NOISE HIGH PSRR LINEAR VOLTAGE REGULATOR Figure 7. VR4 Output Voltage vs. Figure 8. VR4 Output Voltage vs. Temperature, PTAT Mode Disabled
[2]
Temperature, PTAT Mode Enabled
[2] 5.15 5.15 5.1 5.1 t (V) (V) M 5.05 5.05 E E AG AG T T L 5 L 5 VO VO T T PU 4.95 PU T 4.95 T g - S U U O O in 4.9 4.9 n 4.85 4.85 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 io TEMPERATURE (OC) TEMPERATURE (OC) it d
Figure 9. VR4 Output Voltage vs. Supply Figure 10. VR4 Output Voltage vs. Supply
n
Voltage On VDD Pin, PTAT Mode Disabled
[2]
Voltage On VDD Pin, PTAT Mode Enabled
[2] o 5.2 5.2 -40 C -40 C 5.1 5.1 25 C 25 C r C 85 C 85 C e 5 5 (V) (V) E E w 4.9 4.9 AG AG T T L L o VO 4.8 VO 4.8 T T P PU PU T T 4.7 4.7 U U O O 4.6 4.6 4.5 4.5 4.6 4.8 5 5.2 5.4 5.6 4.6 4.8 5 5.2 5.4 5.6 SUPPLY VOLTAGE ON VDD PIN (V) SUPPLY VOLTAGE ON VDD PIN (V)
Figure 11. VR4 Output Voltage vs. Load
[2]
Figure 12. VR1 Output Voltage vs. Load
5.06 3.33 5.04 3.32 5.02 (V) 3.31 E (V) 5 E AG T AG L T 3.3 L 4.98 VO T VO T PU 3.29 T 4.96 PU U T O U O 4.94 3.28 4.92 3.27 0 50 100 150 200 250 300 0 20 40 60 80 100 LOAD CURRENT (mA) LOAD CURRENT (mA) [2] Measured results were compensated for evaluation board losses. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
