Datasheet HMC1060LP3E (Analog Devices) - 5
DescriptionQuad Low Noise High PSRR Linear Voltage Regulator
Pages / Page16 / 5 — HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Absolute …
HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Absolute Maximum Ratings. Outline Drawing. Package Information
HMC1060LP3E QUAD LOW NOISE HIGH PSRR LINEAR VOLTAGE REGULATOR Absolute Maximum Ratings Outline Drawing Package Information
HMC1060LP3E
v00.1211
Stresses above those listed under Absolute Maximum ratings Vdd to gnd Voltage (max / min) +6.5 V / -0.3 V [1] t may cause permanent damage to the device. this is a stress en to gnd Voltage (max / min) Vdd + 0.5 V / -0.3 V rating only; functional operation of the device at these or any M rdx / HVx to gnd Voltage (max Vdd + 0.5 V / -0.3 V other conditions above those indicated in the operational / min) section of this specification is not implied. exposure to thermal resistance 25 °C/w absolute maximum rating conditions for extended periods (Junction to ground paddle) g - S may affect device reliability. the absolute maximum ratings Maximum Junction temperature +150 °C [2] apply individually only and not in combination. in Storage temperature -65 to +150 °C n operating temperature -40 to +85 °C eLeCtroStAtiC SenSitiVe deViCe eSd Sensitivity (HBM) Class 3A oBSerVe HAndLing PreCAUtionS io [1] including short transient events it [2] operation above +125 °C may shorten the lifetime of the device. d operation above +150 °C risks immediate damage to the device. n o
Outline Drawing
r C e w o P noteS: 1. LeAdFrAMe MAteriAL: CoPPer ALLoY 2. diMenSionS Are in inCHeS [MiLLiMeterS]. 3. diMenSion doeS not inCLUde MoLdFLASH oF 0.15mm Per Side. 4. diMenSion doeS not inCLUde MoLdFLASH oF 0.25mm Per Side. 5. ALL groUnd LeAdS MUSt Be SoLdered to PCB groUnd. 6. CLASSiFied AS MoiStUre SenSitiVitY LeVeL (MSL) 1.
Package Information
Part number Package Body Material Lead Finish MSL rating Package Marking [1] 1060 HMC1060LP3e roHS-compliant Low Stress injection Molded Plastic 100% matte Sn MSL1 [2] XXX X [1] 4-digit lot number XXXX [2] Max peak reflow temperature of 260 °C Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
