Datasheet HMC1060LP3E (Analog Devices) - 6
DescriptionQuad Low Noise High PSRR Linear Voltage Regulator
Pages / Page16 / 6 — HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Pin …
HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Pin Descriptions
HMC1060LP3E QUAD LOW NOISE HIGH PSRR LINEAR VOLTAGE REGULATOR Pin Descriptions
HMC1060LP3E
v00.1211
Pin number Function description interface Schematic 1 Vdd Unregulated power supply input t 2 gnd Supply ground M enable input, ttL Logic Level. the Vrx outputs are g - S 3 en floating (high impedance) when en = Low. in n io it d reference voltage (band-gap) output. Cannot be used to source/sink current to/from external circuits. Voltage on n reF pin = 1.17 at +27°C when PtAt Mode is disabled, 4 reF o and equals 1.37 V at +27°C when PtAt Mode is enabled. Must be measured with 10 gΩ meter such as Agilent 33410A, typical 10 MΩ dVM may read erroneously. r C e w 5 HV3 Used with rd3 to set Vr3 output voltage. o P 13 HV2 Used with rd2 to set Vr2 output voltage. 16 HV1 Used with rd1 to set Vr1 output voltage. Sets all output voltages in PtAt mode when connected to 8 PtAtB gnd, default mode when open 6 rd3 Feedback for Vr3. 7 rd4 Feedback for Vr4 14 rd2 Feedback for Vr2 15 rd1 Feedback for Vr1 Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
