Datasheet HMC1060LP3E (Analog Devices) - 7
DescriptionQuad Low Noise High PSRR Linear Voltage Regulator
Pages / Page16 / 7 — HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Pin …
HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Pin Descriptions
HMC1060LP3E QUAD LOW NOISE HIGH PSRR LINEAR VOLTAGE REGULATOR Pin Descriptions
HMC1060LP3E
v00.1211
(Continued...) Pin number Function description interface Schematic t M 9 Vr4 regulator output #4 10 Vr3 regulator output #3 g - S 11 Vr2 regulator output #2 in n 12 Vr1 regulator output #1 io Should contact PCB metallic area for best thermal it Package Base n/C dissipation. Can be connected to ground. d n o r C e w o P Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
