Datasheet HMC1060LP3E (Analog Devices) - 8
DescriptionQuad Low Noise High PSRR Linear Voltage Regulator
Pages / Page16 / 8 — HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. …
HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Evaluation PCB. Evaluation PCB Schematic
HMC1060LP3E QUAD LOW NOISE HIGH PSRR LINEAR VOLTAGE REGULATOR Evaluation PCB Evaluation PCB Schematic
HMC1060LP3E
v00.1211
t M g - S in n io it d n o r C e w o P A sufficient number of via holes should be used to connect the top and bottom ground planes. the evaluation circuit board shown is available from Hittite upon request.
To view the Eval PCB Schematic please visit www.hittite.com and choose HMC1060LP3E from the “Search by Part Number” pull down menu.
Evaluation Order Information
item Contents Part number evaluation PCB only HMC1060LP3e evaluation PCB eVAL01-HMC1060LP3e Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
8
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
