Datasheet HMC1060LP3E (Analog Devices) - 2
DescriptionQuad Low Noise High PSRR Linear Voltage Regulator
Pages / Page16 / 2 — HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. …
HMC1060LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Electrical Specifications
HMC1060LP3E QUAD LOW NOISE HIGH PSRR LINEAR VOLTAGE REGULATOR Electrical Specifications
HMC1060LP3E
v00.1211
t = +25 °C, Vdd = 5.6 V, Unless otherwise Specified, PtAt Mode is disabled, measured at maximum load conditions A in default configuration as shown in Application Schematic. t Parameter Conditions Min typ Max Units output Voltage on All outputs 1.8 5.2 V M default output Voltage Vr1, Vr2, Vr3 default Configuration shown in Application 3.24 3.3 3.36 V Schematic default output Voltage Vr4 4.9 5.0 5.1 V PtAt Mode disabled 2 % g - S output Voltage tolerance [1] PtAt Mode enabled 3 % in input Voltage range (default) 5.3 5.6 V n Max (Vrx) + input Voltage range [2] 3.35 5.6 V io 0.3 V output Current Vr1 [3] t it A = -40 °C to +85 °C 100 mA d output Current Vr2, Vr3 [3] tA = -40 °C to +85 °C 50 mA n output Current Vr4 [3] tA = -40 °C to +85 °C 300 mA o total output Current tA = -40 °C to +85 °C 500 mA output noise Voltage density 2200 10 Hz 120 r C 100 Hz 7 nV/√Hz e 1 kHz 3 10 kHz 3 w 100 kHz o integrated output noise 100 Hz to 100 kHz 1.5 µVrms P Load regulation, Vr4 0 to 300 mA 0.007 % / mA Vr1 PSrr 1 kHz 80 10 kHz 80 dB 100 KHz 72 1 MHz 60 10 MHz 52 Ven = Vdd = 5.6 V; Current Consumption (ignd) 2.1 mA Maximum Load Current Ven = Low; Vrx outputs are floating (high Power down Current 1 2 µA - impedance) in Power-down Mode 0 to 90% of final voltage; Start-Up transient time 50 ms en connected to Vdd 0 to 90% of final output voltage en turn-on delay Cref = 4.7 µF; Cload = 10 µF; Vdd = 5.6 30 ms Ven transition from 0 to Vdd enable input en High Level 2 Vdd + 0.3 V enable input en Low Level 0 0.8 V thermal Protection threshold Junction no loads 150 °C temperature Maximum dissipated Power All outputs Loaded 1.6 w [1] when using external resistors to configure the HMC1060LP3e outputs to non-default levels, the temperature coefficient of external resistors may increase the output voltage tolerance. note that internal resistors have a temperature coefficient of +270 ppm/°C. [2] Minimum input voltage (Vdd) is defined by maximum desired output voltage. As an example minimum input voltage (Vdd) of 4.3 V is required to set the HMC1060LP3e outputs as follows Vr1 = Vr2 = Vr3 = 3.3 V, Vr4 = 4 V. [3] the outputs will withstand short-circuit conditions for a duration of less than 10 seconds. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
2
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
