Datasheet HMC860LP3E (Analog Devices) - 5
DescriptionQuad Low Noise High PSRR Linear Voltage Regulator
Pages / Page10 / 5 — HMC860LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Absolute …
File Format / SizePDF / 699 Kb
HMC860LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Absolute Maximum Ratings. Outline Drawing. Package Information
HMC860LP3E QUAD LOW NOISE HIGH PSRR LINEAR VOLTAGE REGULATOR Absolute Maximum Ratings Outline Drawing Package Information
HMC860LP3E
v01.0811
Stresses above those listed under Absolute Maximum Ratings Vdd to GND Voltage +6.5V / -0.3V may cause permanent damage to the device. This is a stress EN to GND Voltage Vdd + 0.5V / -0.3V rating only; functional operation of the device at these or any RDx / HVx to GND Voltage Vdd + 0.5V / -0.3V other conditions above those indicated in the operational Thermal Resistance section of this specification is not implied. Exposure to 30 °C/W (Junction to ground paddle) absolute maximum rating conditions for extended periods Maximum Junction Temperature +125 °C may affect device reliability. The absolute maximum ratings Storage Temperature -65 to +150 °C apply individually only and not in combination. Operating Temperature -40 to +85 °C ELECTROSTATIC SENSITIVE DEVICE ESD Sensitivity (HBM) Class 1C OBSERVE HANDLING PRECAUTIONS
Outline Drawing
9 T M G - S IN N IO IT D N NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY O 2. DIMENSIONS ARE IN INCHES [MILLIMETERS]. 3. DIMENSION DOES NOT INCLUDE MOLDFLASH OF 0.15mm PER SIDE. 4. DIMENSION DOES NOT INCLUDE MOLDFLASH OF 0.25mm PER SIDE. R C 5. ALL GROUND LEADS MUST BE SOLDERED TO PCB GROUND. E 6. CLASSIFIED AS MOISTURE SENSITIVITY LEVEL (MSL) 1. W
Package Information
O P Part Number Package Body Material Lead Finish MSL Rating Package Marking [1] H860 HMC860LP3E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL1 [2] XXX X [1] 4-Digit lot number XXXX [2] Max peak reflow temperature of 260 °C Inf F or o m ra tip o r n ifc ur e n ,is hd e e d lbiv y e A r n y al oa g n D d evi tco e s p is la beclie ev eo d rtd o ebre sa: H ccur iattti e taen M d re ilicarbloew . H a o ve wev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
9 - 5
978-250-3343 tel • 978-250-3373 fax • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd P e h r o nO e n : 7 -li 81 n - e 32 a 9- t 4 w 70 ww. 0 • Ohi rd tt e ite r on.lc inom license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com Application Trademarks and registered trademarks are the property of their respective owners.Support: apps@ A h ppitlitcitae ti .oco n Sm upport: Phone: 1-800-ANALOG-D
