Datasheet ADP130 (Analog Devices)
Description350 mA, Low VIN, Low Quiescent Current, CMOS Linear Regulator
Pages / Page20 / 1 — 350 mA, Low VIN, Low Quiescent Current,. CMOS Linear Regulator. Data …
RevisionC
File Format / SizePDF / 409 Kb
350 mA, Low VIN, Low Quiescent Current,. CMOS Linear Regulator. Data Sheet. ADP130. FEATURES. TYPICAL APPLICATION CIRCUITS
Datasheet ADP130 Analog Devices, Revision: C
350 mA, Low VIN, Low Quiescent Current, CMOS Linear Regulator Data Sheet ADP130 FEATURES TYPICAL APPLICATION CIRCUITS 350 mA maximum output current VIN = 1.8V VOUT = 1.2V Input voltage supply range 1 VIN VOUT 5 + + V 1µF 1µF BIAS = 2.3 V to 5.5 V ADP130 V 2 GND IN = 1.2 V to 3.6 V 2.3 V < VIN < 3.6 V, VIN can be tied to VBIAS ON VBIAS = 3.6V Very low dropout voltage: 17 mV @ 100 mA load 3 EN VBIAS 4 OFF + Low quiescent current: 25 μA @ no load
01
1µF
0 3- 96
Low shutdown current: <1 μA
06
±1% accuracy @ 25°C
Figure 1.
Excellent PSRR performance: 70 dB @ 10 kHz Excellent load/line transient response Optimized for small 1 μF ceramic capacitors VIN = 2.8V VOUT = 1.8V 1 VIN VOUT 5 Current limit and thermal overload protection + + 1µF ADP130 1µF Logic controlled enable 2 GND 5-lead TSOT package ON VBIAS = 5V APPLICATIONS 3 EN VBIAS 4 OFF +
02
1µF Mobile phones
0 3- 96
Digital camera and audio devices
06 Figure 2.
Portable and battery-powered equipment Post dc-to-dc regulation GENERAL DESCRIPTION
The ADP130 is a low quiescent current, low dropout linear regu- The ADP130 is optimized for stable operation with small 1 μF lator. It is designed to operate in dual-supply mode with an input ceramic output capacitors. The ADP130 delivers good transient voltage as low as 1.2 V to increase efficiency and provide up to performance with minimal board area. 350 mA of output current. The low 17 mV dropout voltage at The ADP130 is available in fixed output voltages ranging from : a 100 mA load improves efficiency and allows operation over 0.80 V to 3.0 V. a wider input voltage range. The ADP130 has a typical internal soft start time of 200 μs. Short- A dual-supply power solution typically improves conversion circuit protection and thermal overload protection circuits efficiency over a single-supply solution because the higher VBIAS prevent damage in adverse conditions. The ADP130 is available supply powers the part, and the lower VIN supply delivers current in a tiny 5-lead TSOT package for the smallest footprint solution to to the load. The power dissipated in the device is thereby reduced. meet a variety of portable power applications.
Rev. C Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2008–2012 Analog Devices, Inc. All rights reserved.
Document Outline Features Applications Typical Application Circuits General Description Table of Contents Revision History Specifications Input and Output Capacitor: Recommended Specifications Absolute Maximum Ratings Thermal Data Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Capacitor Selection Output Capacitor Input Bypass Capacitor Bias Capacitor Input, Bias, and Output Capacitor Properties Undervoltage Lockout Enable Feature Current Limit and Thermal Overload Protection Thermal Considerations Junction Temperature Calculations PCB Layout Considerations Outline Dimensions Ordering Guide
