Document Feedback Link https://form.analog.com/Form_Pages/feedback/documentfeedback.aspx?doc=RH117.pdf&product=RH117&Rev=D KEYWORDS 3-terminal, positive adjustable regulator Link Update Checklist x Document Feedbackx Part No. (A-Master)x Part No (p1) x Analog Footers from Templatex Update TOCx https:// RH117 Positive Adjustable Regulator DESCRIPTIONABSOLUTE MAXIMUM RATINGS The RH117 is a 3-terminal positive adjustable regulator Power Dissipation .. Internally Limited capable of supplying up to 0.5A (H package) or 1.5A (K Input-to-Output Voltage Differential ..40V package). The output is adjusted using two external re- Operating Junction sistors for a range of 1.2V to 37V. The devices have full Temperature Range ... – 55°C to 150°C current limit thermal overload safe area protection, all of Storage Temperature Range ..– 65°C to 150°C which remain functional even if the adjustment terminal Lead Temperature (Soldering, 10 sec) ...300°C is disconnected. All registered trademarks and trademarks are the property of their respective owners. The wafer lots are processed to ADI’s in-house Class S flow to yield circuits usable in stringent military applica- tions. In addition to 883 processing, the RH117 is sub- jected to 100% burn-in in thermal limit. BURN-IN CIRCUITPACKAGE/ORDER INFORMATION BOTTOM VIEW RH117 20V VIN OUTPUT ADJ 2 ADJ INPUT OUTPUT 1 3 2k 61.9Ω H PACKAGE –20V 3-LEAD TO-39 METAL CAN RH117 BI BOTTOM VIEW VIN 2 CASE IS OUTPUT 1 ADJ K PACKAGE 2-LEAD TO-3 METAL CAN OBSOLETE PACKAGE: FOR REFERENCE ONLY Rev. D Document Feedback For more information www.analog.com 1 Document Outline Description Burn-In Circuit Absolute Maximum Ratings Package/Order information Table 1: Electrical Characteristics Total Dose Bias Circuit Table 1: Electrical characteristics Typical Performance Characteristics Revision History
