Datasheet IR53HD420, IR53H420 (Infineon) - 4
ManufacturerInfineon
DescriptionSelf-Oscillating Half Bridge
Pages / Page8 / 4 — IR53H(D)420. Recommended Operating Conditions. Symbol Definition. …
File Format / SizePDF / 72 Kb
IR53H(D)420. Recommended Operating Conditions. Symbol Definition. Minimum. Maximum. Units. NOTE 2:. NOTE 3:. Electrical Characteristics
IR53H(D)420 Recommended Operating Conditions Symbol Definition Minimum Maximum Units NOTE 2: NOTE 3: Electrical Characteristics
The input/output logic timing diagram is shown in figure 1. For proper operation, the device should be used within the recommended conditions.
VB High side floating supply absolute voltage Vo + 10 Vo + Vclamp V V IN High voltage supply — 500 VO Half-bridge output voltage -3.0 (note 3) 500 ID Continuous drain current (TA = 25°C) — 0.7 -P2 — 0.85 (TA = 85°C) — 0.5 A -P2 — 0.6 (TC = 25°C) -P2 — 1.2 ICC Supply current (note 3) 5 mA TA Ambient temperature -40 125 °C
NOTE 2:
Care should be taken to avoid switching conditions where the VS node flies inductively below ground by more than 5V.
NOTE 3:
Enough current should be supplied to the VCC lead of the IC to keep the internal 15.6V zener diode clamping the voltage at this lead.
VBIAS (VCC, VBS) = 12V, CT = 1 nF and TA = 25°C unless otherwise specified. The VIN, VTH and IIN parameters are referenced to COM.
MOSFET Characteristics Symbol Definition Min. Typ. Max. Units Test Conditions
trr Reverse recovery time (MOSFET body diode) — 240 — Qrr Reverse recovery charge (MOSFET body diode) — 0.5 — µC di/dt = 100 I R F=700mA ds(on) Static drain-to-source on resistance — 3.0 — Ω A/µs VSD Diode forward voltage — 0.8 — V
Dynamic Characteristics Symbol Definition Min. Typ. Max. Units Test Conditions
D RT duty cycle — 50 — % fosc = 20 kHz tsd Shutdown propagation delay — 660 — nsec 4 www.irf.com
